20 Most Recent
Panasonic KX TGA270S Cordless Expansion Handset Questions & Answers
How do you get the KX-TGA270S apart to replace the Antenna
Real easy... remove the battery and you'll see 2 screws. then start peeling the phone in half from where the screws were.. the phone may seem like its breaking but it does snap apart... then you will needs a soldering iron to replace the antenna..
I have a Pansonic kx-tga270s that is registered
you dont need to deregister it if you have not registered all 8 hand sets with your base unit. Just register the new one and the base will assign a new # for this new. I you had registered 8 hand sets with your base already, you need to remove(deregister0 one handset from your base(it can take only upt 8).
If it still not registering please deregister as follows:
on the base unit, press program, them mute, then enter 335#, then enter the handset number you wish to deregister.
after deregistering try to register your new hand set.
How do I add an extension handset to my current config?
IF it was a used handset it was likely registered to another base. I just switched bases (1line to a 2 line base). I had to "deregister" the handsets from the old base. I am not sure if you can deregister if the old base is not present? With the old base plugged into power I hit the "function key" at the bottom left of the handset and scrolled down to initial settings. Under registration is "deregistration". I selected that and it put the handset back to its default out of the box. Then simply hit the mute button on the New base and OK on the handset. Worked for all 5 of my old handsets.
Hope this helps
