Wash machine doesn't take water out
Hi
There can be a few causes for this and I have outlined the main things you can check easily yourself below;
1) Check and clear the pump filter on the machine (on most machines this is accesses behind a flap on the front and at the bottom of the machine).
Open the pump filter flap and pull the small drain hose forward. Take the bung out and drain the water into a bowl.
Once you have drained the water, you need to check for blockages in the pump by unscrewing the pump filter. If your drainage is connected to a sink at the other end sometimes a blockage can occur at the point where the drainage hose connects to the sink.
2) At the back of the machine check the drain hoses are not pinched or obstructed in anyway.
3) Check drain pipe stands loosely in the stand pipe. If drainage discharges this way (as opposed to a sink connection) the drain pipe requires an air gap in order to drain properly.
If this fails to resolve the drainage problem other causes can include the pump itself which may be faulty and require replacing or sometimes an issue can occur in the control panel or the door switch on the machine that prevent the machine from entering the drain cycle. These faults will require service assistance to diagnose and repair.
Hope this helps. Please do rate my answer. Many Thanks.
Replace pump
Check pump and drain hose
