SOURCE: mice ate transducer wire
cut the wire and re connect with crimp connectors and then seal withe heat shring tubing and a heat gun (put the tubing in first) or you could solder the ends together and heat shrink tubing over the individual wires. So long as you have a good water tight connection ther should be no adverse affects to your equipment.
SOURCE: mice ate wiring
Try to trace all wires and see if the metal part is still intact. Do not turn it on or allow electricity to pass yet! If wire metal intact, get some good quality black electrical tape and carefully tape all the exposed metal. When done, test system.
To prevent problem, use moth balls, fabric softener sheets, or pine sol soaked on cloths to deter mice & rats. If possible, use old- fashion mouse or rat traps with peanut butter to kill intruders to your boat. If you agressively eliminate them, the problem will be solved, but you may have to periodically repeat the trap use.
It is impossible to diagnose your issue without knowing the YEAR, MAKE, and MODEL of your vehicle.
SOURCE: wiring diagram for headlights 2008 pontiac grand prix
I hate mices to pieces . You can get free wiring diagrams at www.bbbind.com click on technical information . Five box will pop up , click tsb's an free wiring diagrams . Next page go to the bottom an click on I agree. Then next page click on wiring diagrams an then enter your vehicle info , year , make , model , etc... then under system click on lighting , then subsystem click head lamps .
Testimonial: "thanks so much"
