20 Most Recent
Rule 1800 H53SP-24 Swimming Pool Cover Pump Questions & Answers
H53SP-24 pool cover water pump: Pump quit; circuit
I have the same issue. I pulled the pump from the assembly and bypassed the circuit board inside by creating a circuit with the 2 black wires...pump worked fine. Of course, it won't cycle on and off so my guess is that the pressure switch somewhere in the circuit board is bad. Rule has a great warranty as my current unit is a warranty replacement (2 years ago). Last unit had a stamped date code on it. I contacted tech support (
[email protected] ) and got a new one sent out. The replacement did not have a stamped date code, so my fear is that they won't replace this one. I picked one up online for $99 and free shipping. If I get resolution on the broken on, I will have on as a backup.
Good luck and if yours is less than 3yrs old, contact tech support.
6/13/2020 3:40:34 AM •
Rule 1800...
Answered
on Jun 13, 2020
Rule pool cover pump
it is contact rule also theres a date code burned on the side they give it a 3 year warranty
6/3/2015 4:29:22 PM •
Rule 1800...
Answered
on Jun 03, 2015
Why the circuit breaker keep trowing off ?
Could be a short in the cord somewhere. This will keep tripping the breaker. If you can check the socket and plug for loose wires or check for damage along the cord.
8/7/2014 5:25:05 PM •
Rule 1800...
Answered
on Aug 07, 2014
Emerald Vantage Hot Tub Dead
if your GFI trips soon after the spa goes through the purge cycle then you need a new heater.Yes the heater can develop a dead short and it causes the GFI to trip when power is sent to the heater.Rod @ US Parts Center .com
5/9/2013 7:10:21 PM •
Rule 1800...
Answered
on May 09, 2013
