20 Most Recent
Sunbeam 805810 HeatSense Heating Pad Heater Questions & Answers
New heating pad not working
have same problem with heating pad . reset control by unplugging unit for 1 minute , while holding down power button plugged unit back in . sometimes this takes 3 or 4 tries.
Get F2 error code on
Crimped the ends of the heating pad cord where it attaches to the pad a little then did the plug and unplug three times while holding down the on-off button and that did the trick
Have heating pad model 818-7. blinking red light
I had this problem with a heating pad too. I tried turning it off, unplugging it, then plug it back in and see if the light is still blinking. If it's not, set it to the temp you want. My heating pad was very temperamental that way, it didn't want to be set before it was plugged in. I hope this works for you.
MY DAUGHTER GAVE ME THE SUNBEAM LARGE HEATING PAD
I just took mine apart and there is nothing inside that can be fixed (like a fuse.) Sometimes I could get it to work by unplugging it for a minute then plug back in and it would work for a while, but now nothing... It is junk. Walmart has pads for around $15. Also, I found some vibrating heat pads online for around $24.
Malfunction heating pad
Same F2, quick off problem here. Then I noticed that the gray plug on the power cord was not completely flush with the connector on the pad. I shoved them together until there is no gap. The unit's worked perfectly since then.
