You have a chip in your blades. This is most often caused by a nail, screw or small stone imbedded in the wood. The only remedy is to have the blades sharpened.
Snipe is a depression cut on the end of the wood as it passes the blade. This is caused by the incorrect height of the blades in relation to the table. You will find many videos in You Tube on how to set up your planer.
1, Lay pencil on the table top, place body of plane with the front (toe) resting on the pencil, so the light passes beneath the front and middle of the plnes body.
2, lay blade, bevel side up, in to body of plane, ideally sharp end is sticking out of the mouth ever so slightly., 1/2-1mm.
3, Release the knob or lever cam on the lever cap and place on top of blade.
4, tighten knob/turn leaver till it tightens on the blade. and your ready.
5, If the blade isn't protruding the mouth correctly then:
6, Loosen a knob/lever a little to allow the blade to just move, adjust the blade forwards/sidways, lock it in place by re tighten the knob/lever.
Plane a thin piece of wood, re adjust as necessary till wafer thin shavings collect in the mouth ontop of the bevel.
Could be the serpentine belt rubbing on something, but is probably a bearing problem in the belt idler pulley. However, it could be the power steering pump, AC compressor clutch or generator. As the water pump is at the opposite end of the engine, it's probably not that.
pulling is generally caused by one of three things in order of most common.\\ 1. alignment is out. 2. a front brake is locking up. 3. a bad front tire ie. shifted belt, bulge or a high spot
There is no declared max length, although with all wires there is signal attenuation so using higher quality cables will get you better signals at longer lengths. You can also get extenders you can hook in between cables to regenerate the signal so you dont have to break the bank on the really high end cables
this is normal with all planers, when you feed the board in the planer there are two feed roller one on each side of the knives so you get uneven pressure on the board at the start and at the end of the board .when planing boards for a project always add 10"inches or more extras then cut to lenght after planing to thickness required. never cut boards to length before planing .
You need a covering iron. They are used to put the covering on the plane. Lower heat to activate the glue to stick it to the wood around the edges and then higher heat to shrink the covering before pressing it down in the middle.
Use a backing board, such as high grade 3/4 inch plywood under the board you are planing, and you should be able to get down to 1/16, depending on the stability of the board you are planing. Take light cuts and flip it over to cut on both sides. Sounds like you might be making a guitar?
Good luck.
This problem happens repeatedly,when the battery's life is over.
If your mobile shows charging,the charger is fine.when mobile is not charged it is battery problem.
Now,remove the battery and look it closely.The battery shape should be slim and straight.It should not get bulged in any spot.Look,if there is any bulged spot in the battery,consider replacing your battery.
Sometimes,the whole battery seems bulged and if this happens,the battery life is end and over.
This can be identified by keeping your battery in the table and rotating it.If it rotates like a helicopter fan(high speed),surely we have to replace the battery.
