1993 Mazda 626 Logo
Posted on Aug 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Car just stopped running. Lost power suddenly.
Car just stopped running while driving about 40 mph. Lost power suddenly. Won't start. Fuel injected and seems ok. Battery good. No spark to plug wires, tested with calibrated ignition tester. 1993 Mazda 626 4 cyl. Has distributor. Thinking coil and trying to check but coil appears inside distributor housing and no coil secondary wiring from distributor cap to hook up tester to check spark. Trying to trace my way back to find what is wrong with spark. Trying to check for voltage at ignition coil electrical connector but not sure what leads to connect to. Wires are red/black, green, yellow inside this connector. On an older car from 60-70's, I would think coil was gone and needed replacing, but easy to do as they were most likely separately mounted. Appreciate any assistance.
gordy
Level 2:
Sergeant:
Champion:
  • Expert 226 Answers
  • Posted on Aug 18, 2009
 gordy
Expert
Level 2:
Sergeant:
Champion:
Answers
226
Questions
Helped
108024
Points
625
Find an inductive pickup indicator for spark. Place on distributor cap to see if spark is at coil internal tower. If no spark at internal tower, look at ignition module or pickup coil. Ignition modules are prone to failure on 626's. But if you have spark at tower but not at the wire end, then your rotor is gone.
How many fuse boxes are there on a 2005 Toyota matrix XR
Engine compartment
Toyota Matrix - fuse box - engine compartment
Instrument panel
Toyota Matrix - fuse box - instrument panel
Fuses (type A)
Fuse Ampere rating Description 1 FOG 15 Front fog lights 2 HEAD LH UPR 10 Left?hand headlight (high beam) 3 HEAD RH UPR 10 Right?hand headlight (high beam), high beam indicator light 4 SPARE 30 Spare fuse 5 SPARE 15 Spare fuse 6 SPARE 10 Spare fuse 7 ETCS (1ZZ?FE engine with two?wheel drive models only) 10 Electronic throttle control system 8 AMP 30 Car audio system 9 MAIN 30 Starting system, "AM2" fuse 10 DOME 15 Car audio system, clock, personal lights, interior light, trunk light, open door warning light, wireless remote control system 11 HORN 10 Horn 12 HAZARD 10 Emergency flashers, turn signal lights 13 EFI 15 Multiport fuel injection system/sequential multiport fuel injection system, emission control system, "EFI" fuse 14 ALT?S 5 Charging system 15 HEAD LH LWR 10 Left?hand headlight (low beam) 16 HEAD RH LWR 10 Right?hand headlight (low beam) 17 EFI2 (1ZZ?FE engine with two? wheel drive models only) 15 Multiport fuel injection system/ sequential multiport fuel injection system, emission control system 18 TAIL 15 Tail lights, license plate lights, instrument panel lights, instrument cluster lights, clock 19 OBD 7,5 On?board diagnosis system 20 WIPER 25 Windshield wipers 21 AM2 15 Charging system, multiport fuel injection system/sequential multiport fuel injection system, starting system, SRS airbag system 22 STOP 15 Stop lights, high mounted stoplight, anti?lock brake system, shift lock control system, multiport fuel injection system/sequential multiport fuel injection system, cruise control system 23 DOOR 25 Power door lock system, glass hatch opener switch 24 AM1 25 "CIG" fuse 25 ECU?IG 10 Electric cooling fan, anti?lock brake system, traction control system, vehicle stability control system, brake assist system, shift lock control system, cruise control system 26 RR WIPER 15 Rear window wiper 27 A/C 10 Air conditioning system 28 INV 15 Power outlet (115 VAC) 29 P/POINT 15 Power outlet (12 VDC/ in the rear console box) 30 ECU?B 10 Daytime running light system 31 CIG 15 Power outlet (on the instrument panel) or cigarette lighter, car audio system, clock, power rear view mirror control, shift lock control system 32 GAUGE 10 Gauges and meters, air conditioning system, daytime running light system, charging system, auto anti?glare inside rear view mirror, power windows, cruise control system, rear window defogger, back?up lights, front passenger's seat belt reminder light 33 WASHER 15 Windshield washer, rear window washer 34 M?HTR/DEF I?UP 10 Engine control system
Fuses (type B)
Fuse Ampere rating Description 35 ABS NO.1 30 Anti?lock brake system, vehicle stability control system, traction control system, brake assist system 36 RDI FAN 30 Electric cooling fan 37 ABS NO.2 40 (without vehicle stability
control system) Anti?lock brake system 50 (with vehicle stability
control system) Anti?lock brake system, vehicle stability control system, traction control system, brake assist system 38 HEAD MAIN 40 "HEAD LH UPR", "HEAD RH UPR", "HEAD LH LWR" and "HEAD RH LWR" fuses 39 AIR PUMP 50 (1ZZ?FE engine with four?wheel drive models and 2Z ?GE engine only) Emission control system 40 HTR 40 Air conditioning system 41 DEF 30 Rear window defogger, "M?HTR/DEF I?UP" fuse 42 POWER 30 Power windows, electric moon roof
Fuses (type C)
Fuse Ampere rating [A] Description 43 ALT 100 Charging system, "ABS NO.1", "ABS NO.2", "RDI FAN", "FOG", "HTR", "AM1", "POWER", "DOOR", "ECU?B", "TAIL", "STOP", "P/POINT", "INV" and "OBD" fuses WARNING: Terminal and harness assignments for individual connectors will vary depending on vehicle equipment level, model, and market.
Cavalier lost power and now wont start
You should check your fuel pump; it is very commun to Stop working at any moment .see if there is pressure at the injection port,if possible;or remove the throttle body intake hose and spray some starting fluid, close it,and crank it, if it start, your pump is bad. If you car is equipped with timing belt, this is another very commun cause of power lost; you may have a broken timing belt.
2003 honda element - it lost power while driving about 60 mph and then turned to come home.. going about 15 mph and lost power and started jerking - it did not die and the electrical was working - battery...
You should start with the basics, are you getting fuel and air to the engine and spark at the plugs? Is the battery being charged? When did you last change the fuel filter? Does the car still start and run?
2answers
Ford 460 loses power then dies. Starts back up. Idles fine.
It sounds like you might have a clogged catalatic converter on the exhaust system.
1helpful
Car sputters and stalls
IF I UNDERSTAND YOU RIGHT YOU ARE HAVING A MISFIRE ISSUE UNDER LOAD MOST COMMON FIX IS PLUG WIRES. CHECK VEH FOR BASIC TUNE UP FUEL FILTER PLUGS WIRES FUEL INJECTION CLEANING
Engine stalling in stop & go traffic
sound like to me you have a clogged catalytic converter
1helpful
Message ' Reduced engine performance'
sound like transmission slipping .fuel filter clogged.turbo stop woking.dirty fuel injectors.
2answers
95 jetta sputters
i had a similar problem it turned out to be a faulty fuel pump. Any mechanic should be able to do a fuel pressure test. to rule this out
Top Mazda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Mazda Expert? Answer questions, earn points and help others
