SOURCE: ac comes on,but blower does'nt..nothing wrong with blower!!!
check the wiring at the thermostat has anyone touched it g terminal is for the fan
SOURCE: i have a empire propane wall furnace
Check with the manufacturer. Many times these companies offer accessory kits for such application. You will need unit Model #.
SOURCE: Cozy wall furnace (propane) does not respond to
Try jumping the two thermostat wires together to see if the heater starts. If so, replace your thermostat. If not, jump the two terminals where the thermosta twires attach to the furnace. If it starts, you have a bad thermostat wire or connection.
SOURCE: I have a suburban lp furnace and duotherm air/heat
I'm not sure what the problem may be but you could try calling All Seasons RV Appliance Parts & Service. There number is 1-800-344-0673 they have helped me in the past. That and there tech calls are free so it wouldn't hurt to give them a call.
SOURCE: Clare Megasave Propane Furnace. A.C. compressor
You probably have 2 temperature limit switches in thefurnace. One turns on the blower once it is hot enough when the furnace comeson. The second one turns off the gas if the blower fails to come on, or it getstoo hot for some other reason. If the blower fails to start, the gas will keepcoming on until the upper limit switch shuts it off.
Some furnaces use a different relay and coil for a higher speed for fan onlyand A/C is you have it. This means the problem could be the relay too. Most ofthe controls on newer furnaces except the limit switches, are on a board makingdiagnose and repair difficult. In that case you may need to replace the board.
Hope this will help you. Good Luck.
