My Acer AL1916w 19" monitor is only displaying colors in greenish yellow, blue, black, and white (no reds, orange). When I select the desktop and properties/display settings it does not give an option for any other colors to select. Any suggestions? Is it a monitor problem?
Hi, At the worst it is a blown monitor, but have hope. 1st try a new or known good lead, between monitor and PC. 2nd put monitor with own lead on good PC. if 1st works = result. if 2nd and monitor is same, suspect monitor, however, if 2nd works ok on other PC, then look at ur vid card. Either way, this test sequence should save you some $. Be lucky.
