20 Most Recent
Acer X193W LCD Monitor Questions & Answers
I cannot find ideal settings are for my Acer X193W Monitor
The ideal settings for your Acer X193W LCD monitor will depend on your personal preferences and the specific tasks you are using the monitor for. However, there are some general guidelines you can follow to ensure that the monitor is set up and configured optimally.
Here are some recommendations for setting up your Acer X193W LCD monitor:
- Adjust the position and orientation of the monitor to ensure that it is comfortable and easy to view. You may need to adjust the height and angle of the monitor, as well as the distance between your eyes and the screen, to find the most comfortable and ergonomic viewing position.
- Set the resolution of the monitor to the highest supported resolution. This will provide the sharpest and most detailed image, and will ensure that the monitor is able to display high-resolution graphics and text clearly.
- Adjust the brightness and contrast settings to a comfortable level. The ideal brightness and contrast settings will depend on the ambient lighting in your workspace, as well as your personal preferences.
- Configure the color settings to match the color gamut of your primary display. This will ensure that the colors on the Acer X193W LCD monitor are consistent with the colors on your primary display, and will prevent any color shifting or mismatching between the two displays.
- Enable any additional display features or settings that may be available on the Acer X193W LCD monitor, such as advanced color settings, color temperature controls, or dynamic contrast controls. These settings can help improve the overall image quality and viewing experience on the monitor.
Overall, the ideal settings for your Acer X193W LCD monitor will depend on your personal preferences and the specific tasks you are using the monitor for. Experiment with different settings and configurations to find the settings that work best for you.
Acer X193w screen turns on
Its your computer/cable. Either the cable is damaged or the the display chip of your motherboard is defective.
My Acer X193W power light is orange and it flashes
the problem is not in to your Monitor the problem is in your PC
- press your keyboard nun lock if working and if the light of the keyboard is Green.
- remove the memory of your pc and clean it
- also check your video card
remove your LCD monitor from the pc and check if you can press the menu of your LCD monitor if that working means your pc is the one have a problems
When i start the game
Skip the Game intro by pressing the enter key.Then move your mouse to the toppest position .Then press the down arrow.You will hear a sound.Press again and press enter[now you entered options menu]Press enter[now in settings]Press left arrow key to decrease resolution[4times]press enter .Press again to confirm.hope you problem is gone .I had the same problem and I used this way to solve that.
Signal over range.
Could be a driver issue with your monitor. Safe mode bypasses them with working defaults.
Input not supported acer x193w
Hello Shaul
Hints:
1) Change to Plug and Play monitor driver
2) try changing the screen resolution on the PC, and driver.
3) try changing to 60Hz the refresh rate of the monitor on driver section or options on the monitor driver.
Carl
Windows XP Pro. driver for the acer LCD Monitor X193W
To my knowledge, it is compatible and certainly would work with XP. Since this monitor has both DVI and VGA inputs make is compatible for most video cards or even a built-in video of the PC. If for some reason the Acer X193W would not work with your Windows XP PC, possible reasons are:
- Screen Resolution and/or Screen refresh Rate of the PC's Display Properties too high, try lowering them down;
- hardware fault either on the monitor or video card;
- incorrect/missing drivers of the video card;
- it is being hooked as a secondary monitor and the dual/twin view is not activated.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
My acer pc is not booting properly
there maybe faulty installed hardware on your PC. remove those hardware like sound & video card (if any), PCI modem, CD/DVD ROM, etc. turn on your PC without those hardware & if/ there's nothings change?..it means that there is no wrong with your PC's hardware. turn the PC off, re insert IDE & power supplies cable of your hard disk drive to make it sure that the HDD is properly connected & being detect by the system. remove the memory card and clean or wipe the connector surface of the RAM with tissue paper. (change new memory card if needed). check the mother board C-MOS 3 volts battery if it is volts sufficiently .turn your desktop on & wait for good results.( Reformatting your OS is also recommended.)GOOD LUCK!
My 5.6 inch colour screen starts but only black and white shows
Well it sounds like you un-seated the cable that send the picture to to the monitor. The reason you are only getting a white screen is that the backlight is on but there is no data coming through to display.
The cable usually is a ribbon that fits into a slot. The slot then locks by pushing down on the cable and that makes the connection. It is easy to pull this cable out of the slot slightly (or all the way) and this will cause the problem that you are experiencing.
I'm not sure of your exact model but the cable and connection looks something like this:
http://mwolk.com/blog/wp-content/uploads/2009/06/laptop_screen_replacement_datacable.jpg
As for fixing your wireless, you usually don't need to do anything to the laptops display. You should be able to remove the bottom cover and access the wireless card from there. The antenna are the black and white wires that are coming off the wireless card.
You can check those connections as well as, in most cases, remove the card and replace it with one that works. This should be a picture of your model or similar, you can see where the wireless card is located:
http://www.insidemylaptop.com/images/Acer-Aspire-5610z/lapatop-disassembly-03.jpg
