I have a GB of pc3200 DDR (400 MHz) in my Dimension 2400. I would expect it to run at 333MHz but it is running at 266MHz.
How can I fix this please? I am very wary of BIOS upgrades, is there an alternative?
Peter Honeyman
You can go to Bios ser up and find the instruction of over clock (if your main support this function) Be careful when you do it as your computer will run with more energy consumed and become hot. You need bigger fan or additional fan th extract the heat out.
Alternatilvely, you go Start - Run and type msconfig. It will show the config table, you then go to start up menu, uncheck all unnessary programs there. Reboost your computer. It will help system run faster.
Hi there
this is very interting you are asking for fsb to adjest at 333mhz.
for this first you have to look your prosser fsb , *********** board fsb and your ram fsb.
fsb is a front side bus on which data ia is running at speed but for high speed you have to increase your fsb you are askin (ie:333mhz). itell you how?
example : your prosser fsb is 266mhz
your ram fsb is 400mhz as you told
*********** board fsb is 333mhz
now you system fsb is constant on 266 mhz because system on that fsb witch supporting by ram prosser and mobo( motherboard).
if you want to increase the fsb you have to buy mobo, ram,and prosser at same fsb.
