Old hotpoint upright freezer only has 1 temp artic blast....
Hotpoint freezer model # fv12crb only has one temp. Everything gets freezer burn. Destroys food...only good for storing ice. Where should I start in fixing problem? Thermostat?
Re: old hotpoint upright freezer only has 1 temp artic...
I would replace the thermostat because is the only thing that controls the temp. , also there's a timer and a terminator but them are only for defrosting the unit.
red light flashing means temp. is too high (not freezing) just an indicator to let you know that there is a problem
let me know: the freezer temp. (use a temp. reader)
any unusal ice build up on the back freezer panel?
is the freezer fan running?
compressor running?
parital frozen foods?
Use a freezer thermometer and tell me the actual temperature. Or at least store some ice cream and see if it stays brick hard. Unless I have some idea of the actual temp I can't tell if defective freezer or alarm
I have an upright freezer which temp was unstable. The coils were frosted up, and the circulating fan was unable to pull air across the cooling fins.I defrosted the unit, cleaned it up, and turned it back on. Worked fine until it frosted up again. The unit was a no frost model. I had to have it serviced, and one of the defrost sensors was bad. No problems since this was fixed.
