20 Most Recent
Hotpoint 3.5 cu. ft. / 99 liter Upright Freezer RZA30 Questions & Answers
Hotpoint Freezer
Get a hold of CAMCO, they are the authorized parts/repair depot for Hotpoint
Have an RZA30 freezer thats not freezing
was the compressor running? if the unit fails to make temp at a given setting and the compressor is running then turning down the cold control will not make it colder. the thermostat is a switch that turns the compressor and fans (if you have fans) on and off. the different settings only change at what temp the compressor etc. turns off. make sense? so listen for that compressor if it is running and the unit is war you have refrigeration system trouble: restriction, low charge, leak, etc...
cant tell you which without more info.
What do the control buttons do on a Hotpoint Ice Diamond R134A do please?
Could you please recheck for the model number. R134A is a reference to the coolant used in the freezer mechanism.
Orange is often a reference to the 'Fast Freeze' function being turned On. Green is showing the freezer unit is at the correct temperature. Red is warning the freezer is Too warm. Some freezers are fitted with an 'Economy' function where the freezer can be run at a lower power level when not used regularly such as when on holiday.
8/2/2022 5:09:29 PM •
Hotpoint...
Answered
on Aug 02, 2022
My FFA70 fridge/freezer is causing my circuit
kevinmdoyle... Hello and welcome to FIXYA,
Yours is a UK model... so I (usa) can't help you
on SPARES (motor start capacitor) ...
however
Circuit breakers do go bad...!!
(easiest & cheapest to check first)
MUCH Easier to test the idea than you would imagine:
- Shut OFF your
main breaker.
- Open your panel & swap the wire with an EQUAL breaker
- Tag the wires (to restore when finished trouble shooting)
- Restore the main breaker (wait & see)...
and don't forget to clean that CONDENSOR
per owner manual instructions.
If the failure persists... RESORE the BREAKERS.
and
HOPE it is the START CAPACITOR on your compressor.
Carnac the Magnificent
1/15/2018 3:11:44 PM •
Hotpoint...
Answered
on Jan 15, 2018
