Electrical Supplies Logo
K
Kim Gate Posted on Jun 22, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can i get breather filter box for PowerG 1200 c generator
sherlywang
Level 3:
Master:
  • Master 428 Answers
  • Posted on Oct 11, 2019
sherlywang
Master
Level 3:
Master:
Answers
428
Questions
0
Helped
198583
Points
1063
High qality diesel generator set website: www.dieselgeneratortech.com
2004 Chevy Trailblazer 4.2. How do I get moisture out of my breather box
That could mean your PCV valve/system has a problem and isn't removing excess pressure from your crankcase.
During the power stroke of the engine, the gasses from the crankcase are forced upward, and if the PCV isn't functioning properly to route the gasses to the intake to be burned, the pressure will push oil upward past the piston rings and into the intake.
I'd start by checking/testing the PCV to make sure it's functioning properly. If you have a PCV valve, it may need to be replaced.
2answers
Oil and fuel mixing.
you need to clean out the sump air vent. and change the filter for the air breather. some are fitted with a clean easy filter you take off and wash out.
Getting oil on the air filter and when im riding it blows back on the exhaust.
It helpes if you have oil only 1/2 way up on stick,, + some tie the breather tubes together w/ a T then down to a small breather / filter ..& mount filter under motor.. may i suggest harleytalking.com good group have helped me...
My 2006 1200c gets alot of oil in the air filter but im told there was no umbrella valves deigned in this model is this true
Since there is no "center section" to the rocker boxes, there is umbrella valve in there. There is a "breather" in there however. Now, whether or not it will cause excessive oil to get into the air filter, I don't know. I don't work on models as new as this. It's simple enough to put the front rocker box and check. Take a look here.
http://www.bikebandit.com/2006-harley-davidson-motorcycle-sportster-1200-custom-xl1200c/o/m18599
Good Luck
steve
1helpful
Harley motorbike why blow back thru new motor 4000 k,old
Regrettfully, all Harley engines suffer from this problem to a greater or lesser degree. It is due to the use of the single crankpin design of the engine. This design is what gives the Harley-Davidson it's distinctive sound but it does create a tremendous amount of crankcase pressure. This is due to the two very large piston moving up and down in unison with each other.
The late model engines went to what we call a "head breather" design in that crankcase pressure is relieved at the top of the engine rather than the earlier design that relieved the pressure at the lower side of the engine. This is accomplished by the use of "umbrella valves" in the center piece of the rocker box covers. The "umbrella valves" are made of synthetic rubber and open and close the breather passages from the rocker box to the air filter box by flexing in responce to the crankcase pressure. Due to repeated heating and cooling, the umbrella valve gets a bit stiff and fails to seal completely allowing oil to be blown into the air filter. Sportsters are more subject to the problem than the Big Twins for some reason.
Most people purchase one of the aftermarket crankcase breather systems and install this or they simply reroute the crankcase breather to the underside of the engine using longer hoses and plug the holes in the backside of the air filter assembly.
However, if the laws in your area preclude you of making any modifications such as this, I would purchase a K&N washable filter and install it in the air filter assembly. These filter are washable and can be cleaned and reused over and over again. As I said, this oil getting into the air filter is aggrevating but also normal unless it gets to where it's pouring out everytime you ride it after cleaning. At point, you need to replace the gaskets and umbrella valve in the rocker boxes. Good Luck
5helpful
5answers
Missing Manual
Here is a link for the manual....Sorry for the quality, it's printed on glossy paper, and difficult to scan properly.
http://rapidshare.com/files/285883408/GT-1200C_Manual.pdf.html
Click on Free User, wait the few seconds, and then click on the download button.
Good luck,
fields
Carb spittin out fuel when using throttle
change the air filter they spit oil out of the breather tubes that are connected to the rocker boxes when the air filter gets dirty the air pressure lowers on the cleaner side of the carb and then the fuel wants to go to the lower pressure making it come oput of the airfilter side
5helpful
Oil blow out the breather
An overfull oil tank will do it. Even if not overfull just about all harley's will blow oil out the air filter. Unless there is a bunch of oil coming out, it's not a problem What I've found is that the air filter eventually gets saturated and then starts to leak through. The level in the oil tank doesn't seem to matter. If you change the air filter the problem goes away, until the new one gets saturated and then it starts all over again. My plan is to get a K&N air filter, which you can clean yourself and save having to buy a new air filter every 4,000 miles or so.
Top Generac Electrical Supplies Experts
vince
Paul Bade
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
