20 Most Recent
Eastern Tools And Equipment 1200 Watt Portable Generator #TG1200E Questions & Answers
I have a ETQ
You can buy parts and get advice from Generator Guru. Their website is GeneratorGuru.com
I'm looking for a manual/guide for the Power G
The Power GT-1200C is a 4-cycle engine.
Here is a link for the manual....click on Free User, wait the few seconds, and then click on the download button.
http://rapidshare.com/files/285883408/GT-1200C_Manual.pdf.html
Good luck,
f.
Missing Manual
Here is a link for the manual....Sorry for the quality, it's printed on glossy paper, and difficult to scan properly.
Click on Free User, wait the few seconds, and then click on the download button.
Good luck,
fields
Where to buy an air filter for tg3000 generator
Call 800 number or go online and look up repair parts dealers. These are Chinese generators and parts are hard to find. Also check with Tractor supply they can order parts for most of them.
Removing carborator
To remove the carb, first undo the 2 bolts on the front of the panel to expose the air filter area. Then undo the 2 nuts either side of the carb air hole. This will help you remove the rest of the control panel, reveiling the carb.
Have a portable generator question? We are always happy to help. Generatorguru.com
Generator Guru
What type of oil is use for dg6ln
If the unit you have is a four cycle engine " no oil/gw mixing required ..use any good SAE 30 oil...no multi grade needed...good luck...
