Dear sir
good day
to fix up such problem
Clean the printhead, then print and
Verify that inkjet paper is loaded in the paper trays.
On your desktop, start the KODAK All-in-One Home Center, then select the Help [?] icon.
From the Help menu, select Maintenance, then select Printhead Cleaning. The On/Off light flashes green during the cleaning procedure.
When the On/Off light glows a steady green, press Photo + Copy simultaneously to print a demo sheet
and you have to Replace ink cartridges.
IMPORTANT: Make sure you are using KODAK Ink Cartridges. Your KODAK All-in-One Printer is designed to work with KODAK Ink Cartridges. Kodak is not responsible for the compatibility or performance of either non-Kodak brand ink cartridges or refilled ink cartridges. To purchase KODAK Ink Cartridges, go to KODAK Ink Cartridges & Photo Value Packs.
Lift the printer access door, then remove the ink cartridges from the printhead.
Insert new KODAK ink cartridges into the printhead, then press down firmly until you hear the cartridges click into position.
Close the printer access door, then make the same print.
* Re-seat the inks both color and black then try printing * Re-seat the Printhead of the printer then print again * if problem still persist call 1800 421 6699 and the technical rep will replace the printhead
throw out your printer and buy another brand. if you call18002356325 the call goes to manila and chances are you will be talking to some one who only speaks partial english and knows nothing about kodak products but will read to you from these internet instuctions that you just read !!! kodak has become a very anti-american company in so many ways!!!
Please call 1.800.421.6699 and select option 01 for prints missing black or color ink. Kodak will send you a replacement printhead kit for free. I hope this helps.
just to check, is what specific lights is blinking is it the check color or just check black inks?? -to make sure w/ this one is it blinking too fast or slow and what is the color?? check if the on and off is also blinking
-check black ink and check color cartridges blinking fast means no printhead installed
-check black ink and check color cartridges blinking slow, no cartridges installed
-check black ink and check color cartridges blinking w/ on and off ready to calibrate (in ready to calibrate if doing nothing, just press cancel and
-press photo and cancel on printer, if not doing anything
-remove printhead( the one that holds the cartridges) turn printer on and off, put printhead back to printer w/ cartridges, and check the lights that is blinking
-press photo and cancel again -if not doing anything, contact manufacturer -goodluck
OK so i found some new information that should solve the problem. The version of firmware you originally had on the printer when you changed the ink cartridge was bad. There is a known issue that when you put in a new ink cartridge when the printer is in the error state "COLOR INK CARTRIDGE EMPTY. REPLACE COLOR INK CARTRIDGE" the unit writes that value to the new ink cartridge so you will continue to have that error. So to fix your problem First Remove the ink cartridges and download and install the new Firmware. Then sadly you have to go get another new ink tank and install it.
If you can get through to kodak you should request reimburstment of some sort like a free set of ink tanks.
