20 Most Recent
Kodak EASYSHARE 300 Photo Printer Questions & Answers
I have a Kodak ESP 3250 printer and I use Google
Can you copy directly from camera to your USB-connected PC?
Or if the camera uses an SD card, use the card as a drive in a card-reader.
Then try to upload using Picasa.
Otherwise see if Kodak HS has user-options to bypass this.
Or contact Kodak.
Will the kodak 3000DSV work with win 7
From what I read, you would need to install the firmware update for W7 compatibility:
http://support.en.kodak.com/app/answers/detail/a_id/16994/~/kodak-easyshare-photo-printer-300-firmware---windows-operating-systems/selected/true
I can't get my kodak
You have to clear the queue that the printer is following.
Go to start... control panel... devices or hardware or something and find your printer. Double click and it should open a window showing you the job list that the printer is following.
Right click on the old documents and clear them.
Now give the new command. It should print just fine.
I have a kodak formatted
There is a little switch on the side of that card , if you flip that switch you can format and write to this card but as of right now the card is set for read only functions.
