SOURCE: transported refridge at 45 degree angle about
Thats not to bad should be about 28 % F. but it depends on how old the thing is.
SOURCE: Default temperature settings
You can't reset the fall back temp. Check out the set back unit you can buy at a local Toyo dealer. It has a built in power failure failsafe that might help your situation.
SOURCE: Rinnai Infinity 26 hot water system set to 55
If you aren't getting any error codes, then the heater is probably doing its job. Your problem is probably somewhere in your plumbing system. The most common reason you get this sort of problem is due to cold water mixing in the hot water system. There are a number of causes for a "cross connection" :
-Faulty check valve
-Missing check valve on reciculation return line
-Faulty shower cartridge
-Thermostatic mixing valve set too low
-Faulty thermostatic mixing valve
-Faulty anti-scald valve
The easiest way to confirm a cross connection is to: 1) shutoff the cold water entering the tankless heater 2) open hot water valves around the house. If you still have water flowing at your hot water fixtures, then you have a cross connection.
SOURCE: Freezer is not freezing.
Need more info? Name and model of freezer or fridge? Can you here the compressor running in back of the fridge. Making any weird noises?
Thanks,
Randy
SOURCE: why is is my SAT setting not working on my infinity fx 35 factory radio?
Best Manuals
My problem was easily solved. I hope your too :))
