20 Most Recent
Traulsen G-Series G22000 Solid Door 2-Section Freezer Questions & Answers
Traulsen 6 half door moel 31300 freezer
To check if the expansion valve is faulty in your freezer, you can follow these steps:
- Safety Precautions: Ensure the power is disconnected and the freezer is fully defrosted before proceeding.
- Locate the Expansion Valve: The expansion valve is typically located near the evaporator coil in the freezer. It is a small valve with an inlet and outlet.
- Visual Inspection: Inspect the expansion valve for any visible signs of damage or leaks. Look for corrosion, loose connections, or frost accumulation around the valve.
- Temperature Measurement: Use a thermometer to measure the temperature at different points in the refrigeration system. Check the temperature at the inlet and outlet of the expansion valve. There should be a noticeable temperature drop across the valve.
- Pressure Measurement: If you have the necessary tools and experience, you can also measure the pressure at the inlet and outlet of the expansion valve using a pressure gauge. Compare the pressure readings to the manufacturer's specifications to determine if the valve is functioning properly.
- Consult a Professional: If you are unsure about performing these checks or don't have the necessary tools, it is recommended to contact a professional technician or an authorized service center. They will have the expertise and equipment to accurately diagnose and repair any issues with the expansion valve.
6/28/2023 5:23:12 AM •
Traulsen...
Answered
on Jun 28, 2023
Solenoid diagram
that sounds like the hardstart relay that energizes the start windings in the compressor . if that or more likely the capacitor fails when it is first energized the compressor will pull excessive amps and cause the overload protector to open until it cools for a minute or two.
5/22/2014 5:40:12 AM •
Traulsen...
Answered
on May 22, 2014
Bad Temperature Controller
you can go to either aJohnstone Supply, United refrigeration, or baker supply, Insco Distributing, refrigeratin hardware supply company( they shio it from eithe dunver or someshere in california
Thank for using FixYa
12/24/2008 5:29:28 AM •
Traulsen...
Answered
on Dec 24, 2008
