Casio G-Shock G 520D 4AVDR  Cockpit Series watch Logo
Posted on Aug 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Manual Please need a full owners manual 4 a Casio G-Shock cockpit series G 520D 4AVDR to set the time
Arturs Kalnins
Level 3:
  • Master 2,338 Answers
  • Posted on Aug 13, 2009
Arturs Kalnins
Master
Level 3:
Answers
2338
Questions
9
Helped
1814252
Points
13579
You can find it here:
http://world.casio.com/wat/download/en/manual/
Rate me, please.
Casio G-510 G-Shock Cockpit Series G510-6 Adjusting time
you need to look at the user manual that
you can download a soft version of the user manual on below link. .when you open the link just write the 4 digits code on the back side and click searched on the URL below
Hope this helps! Take care and please Remember to rate/vote and
give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
CASIO Watch User Manual Archives
Use this page to download a copy of CASIO watch manuals in PDF format.
To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
1helpful
I don`t have a manual and I want to cancel the alarm. What will I do?
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
How do i change the analog time on my casio g-541d
Hi,you need to look at the user manual..
just in case ,if you need to download a soft version of the user manual pls visit the URL below..
Hope this helps! Take care and please Remember to rate/vote and give me
Thanks
CASIO Watch User Manual Archives http://world.casio.com/wat/download/en/manual/
Cant set it
    Setting the Time
  1. G-Shock watches feature a digital display that is set using the function buttons on the outside of the watch face. To set the time, press and hold the the upper left button until the seconds unit blinks on the display. Reset the seconds to "00" by pressing the lower right button.
    Push the lower left button to switch to the hours unit, which will start blinking. Advance the hour by pressing the lower right button. If you hold down the lower right button, it will advance the hour unit at a higher rate of speed. Once the hour is set, press the lower left button to switch to the minutes unit. As with the hours unit, pressing the lower right button will advance the minutes and holding it down will advance the minutes rapidly.
    Once the time is set, press the upper left button to save the setting.
  2. Backlight
  3. The backlight on a G-Shock watch has a manual control and an automatic function that will light the face of the watch whenever the alarm, countdown alarm or hourly alarm ring. To use the manual backlight, press the button on the bottom of timepiece. The light will glow for approximately 2 seconds before going out.
    The automatic function is set by pressing and holding the lower right button. When the automatic function is set, an indicator icon will display on the watch face above the seconds unit. You can turn off the automatic backlight function by pressing and holding the lower right button until the icon disappears.
    Note that backlight causes a drain on the battery, and overuse of the backlight will greatly reduce battery life.
  4. Setting the Alarm
  5. The G-Shock has an alarm that emits an audible tone for approximately 20 seconds when it turns on. To set the alarm, press the lower left button until "AL" displays in the upper left corner of the timepiece. Press and hold the upper left button until the hours unit starts to blink. Adjust the hour by pressing the lower right button. As when setting the time, you can advance the hour at a higher rate of speed by holding down the lower right button.
    Once the hour unit is set, press the lower left button to advance to the minutes. Use the lower right button to set the minutes. Follow these same instructions to set the month and day you want the alarm set.
    When the alarm time and date are entered, press the upper left button to save the setting. Push the lower left button three times to return the G-Shock to "Timekeeping" mode.
Hello there, how do i set the hr and minute hands on my watch.the digital clock is fine. thankyou Colin
For that I need to know how many buttons you have on your right side of the watch. Anyways this is the solution in case you have just one knotch on the right side of your watch. Slowly pull out the round knob on the right side of your watch. It comes out in two stages (in case your watch has date also) or else just one pull will be there. After pulling the knob out you can rotate and set the time and then push it back. your time is set.
4helpful
How to put the time forward a hour
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals.Rate me, please.
6helpful
I have a casio G-Shock watch,And recently had a fresh battery installed, How do I reset to the Atomic Clock? Not getting the Signal.
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals. Rate me, please.
2helpful
I cant change the time on my cassio g-shock (G-1000D)
LIVING IN IRELAND AND MOVED TO AUTRAILLA AND DONT NO HOW TO CHANGE THE TIME ON MY G SHOCK WATCH
Select "support" and the "manuals", watches;
Accept terms
Click on "search" and the download your instructions.
2helpful
How do you set the time with the hands on a CASIO G SHOCK 314 WATCH
If you've lost the manual, you may find it here on the Casio site
Top Casio Watches Experts
k24674
Robert
ZJ Limited
ZJ Limited
Are you a Casio Watch Expert? Answer questions, earn points and help others
