20 Most Recent Casio G-Shock G 520D 4AVDR Cockpit Series watch Questions & Answers
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Casio G-Shock G... | Answered on Feb 16, 2011
    Setting the Time
  1. G-Shock watches feature a digital display that is set using the function buttons on the outside of the watch face. To set the time, press and hold the the upper left button until the seconds unit blinks on the display. Reset the seconds to "00" by pressing the lower right button.
    Push the lower left button to switch to the hours unit, which will start blinking. Advance the hour by pressing the lower right button. If you hold down the lower right button, it will advance the hour unit at a higher rate of speed. Once the hour is set, press the lower left button to switch to the minutes unit. As with the hours unit, pressing the lower right button will advance the minutes and holding it down will advance the minutes rapidly.
    Once the time is set, press the upper left button to save the setting.
  2. Backlight
  3. The backlight on a G-Shock watch has a manual control and an automatic function that will light the face of the watch whenever the alarm, countdown alarm or hourly alarm ring. To use the manual backlight, press the button on the bottom of timepiece. The light will glow for approximately 2 seconds before going out.
    The automatic function is set by pressing and holding the lower right button. When the automatic function is set, an indicator icon will display on the watch face above the seconds unit. You can turn off the automatic backlight function by pressing and holding the lower right button until the icon disappears.
    Note that backlight causes a drain on the battery, and overuse of the backlight will greatly reduce battery life.
  4. Setting the Alarm
  5. The G-Shock has an alarm that emits an audible tone for approximately 20 seconds when it turns on. To set the alarm, press the lower left button until "AL" displays in the upper left corner of the timepiece. Press and hold the upper left button until the hours unit starts to blink. Adjust the hour by pressing the lower right button. As when setting the time, you can advance the hour at a higher rate of speed by holding down the lower right button.
    Once the hour unit is set, press the lower left button to advance to the minutes. Use the lower right button to set the minutes. Follow these same instructions to set the month and day you want the alarm set.
    When the alarm time and date are entered, press the upper left button to save the setting. Push the lower left button three times to return the G-Shock to "Timekeeping" mode.
Casio G-Shock G... | Answered on Aug 19, 2010
For that I need to know how many buttons you have on your right side of the watch. Anyways this is the solution in case you have just one knotch on the right side of your watch. Slowly pull out the round knob on the right side of your watch. It comes out in two stages (in case your watch has date also) or else just one pull will be there. After pulling the knob out you can rotate and set the time and then push it back. your time is set.
Casio G-Shock G... | Answered on Jun 13, 2010
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals.Rate me, please.
Casio G-Shock G... | Answered on Mar 31, 2010
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals. Rate me, please.
Casio G-Shock G... | Answered on Mar 05, 2010
Select "support" and the "manuals", watches;
Accept terms
Click on "search" and the download your instructions.
Casio G-Shock G... | Answered on Feb 09, 2010
You can find it here:
http://world.casio.com/wat/download/en/manual/
Rate me, please.
Casio G-Shock G... | Answered on Aug 13, 2009
On the case back usually or user manual
Casio Watches | Answered on Oct 06, 2019
depends on your use of watches and the environment you tend to be in. If you are somewhere that allows you to see whether there it is day or night, than using 12 hr setting will work just fine. However if you're in a place that keeps you secluded and you are not able to determine whether it is day or night than 24 hr. setting will help you keep track of not just the time, but whether it is day or night.
Casio Watches | Answered on Sep 30, 2019
Could be poor battery contact
Casio Watches | Answered on Sep 27, 2019
I have one also and number is 612574 so that must be a serial number. have no idea of value.
Casio Watches | Answered on Aug 30, 2019
To set time and date, you must in "Time Keeping Mode" (display day, date & time) then press and hold the left-up button until it start flashing. To set press right-down button, to go next setting press left-down button.
To toggle between 12-hour to 24-hour, again, must in "Time Keeping Mode" then press right-down button.
here is the manual https://support.casio.com/storage/en/manual/pdf/EN/009/qw2672.pdf
Casio Watches | Answered on Aug 19, 2019
Casio G-Shock G 520D 4AVDR  Cockpit Series watch Logo
Popular Tags
11 questions posted
Top Casio Watches Experts
Janelle Schoonover
Janelle Schoonover
Ekse
Are you a Casio Watch Expert? Answer questions, earn points and help others
View Most Popular
Casio Watches
  • Casio Watches
Most Popular Question
don t manual
  • Watches
