SOURCE: Yamaha outboard motor manual
You got it :
http://www.yamaha-motor.com/outboard/service/viewmanuals/outboard_manuals.aspx
here !
SOURCE: 40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
SOURCE: mercury outboard over charging
Your motor is fine. It needs to put out more than 12 volts or the battery will not charge. Most alternators put out between 13 - 17 volts, so this is well within the range.
SOURCE: Wiring to and from rectifier and to charge the battery
I need more info than that, Is it electronic ignition? Call me when you have a chance or check out www.lambretta.net
