Remove top and front panel on dryer to access drum and replace drive belt. https://www.6ya.com/callphilipforhelp
SOURCE: Amana Dryer belt instalation
Remove the power to the unit and the bottom access panel. Remove the front bulkhhead where the drum sits on by undoing four screws one for each corner.Verify felt seal on exhaust fan cover is airtight on flange of duct. If seal is installed improperly air flow will be restricted which can cause poor dryer performance.Belt must be positioned around cylinder between center and rear bafflescrews with the ribbed surface against the cylinder. You gotta push up on the spring loaded idler pulley the easily slip on the belt to the motor shaft. make sure that the ribbed part of the belt wraps around the drum and motor shaft and not kinked.
SOURCE: Amana dryer belt
You will probably have to open it up from the top and/or back. If the belt looks alright (it probably won't, though), check the belt tensioner. Carefully observe how the belt goes on and around the tensioner before replacing.
SOURCE: How to open the dryer and replace the belt
all dryers open from the top so open the dryer door and look inside the top edge you will see two screws . remove the screws and lift the top panel . the front panel has two screws on the top one on the left and one on the right remove them both and lift up the front panel to remove it. the only way you can install the new belt is removeing the front panel because the belt goes around the drum from the front. once you remove the old belt out put the new one in . the belt goes around the drum from the front and then to the motor and idle roller . you can reach the idle roller from the front left corner or from the back of the dyer? i like to install them from the back cause its more easy. in the back of the dyer where the hose goes connected to the blower is the top with four screws remove the hose from the blower tube and remove the four screws. after you remove everything you should be able to see the dryer motor and idle rooler put the belt over the motor first then over the idle rooler .always make sure when you do this the dyer is unpluged and after your done plug it back and turn it on to make sure it runs correctly . if it runs ok put everything back together again.
SOURCE: No heat coming from Amana Dryer
2 screws at the bottom of front panel if no screws there, then pry top off with wide flat screw driver then look inside toward top of front panel remove two more screws and the front should lift right out then remove screw/s in center of drum and lift out of cabinet there should be your heat element
SOURCE: I have Amana electric dryer, model number LEA30AW.
There are 2 screws along the bottom and the lower panal will drop down and off. You can look in from there.
Eric
