SOURCE: Ice maker only produces 30 cubes per day (24 hrs) since new.
You probably need more water pressure going to the frig. check that first.!!
SOURCE: where do I get my omron bp monitor calibrated
I assume you mean checked for accuracy - something that you should do every two years. I assume you live in Canada or the US, if so please contact OMRON at the number below. They will be able to direct you to a service centre near you.
CONSUMER SUPPORT TOLL FREE NUMBER: 1-877-216-1333
Customer Service Representatives are available
Monday through Friday - 8:30am to 4:30pm CT
SOURCE: how do I reset the time & date on the omron
First find a small stick (toothpick?), then turn on the unit (O/I button). Now hold hold down the DATE/TIME button for 2 seconds. Use the up arrow and down arrow (beside the display), to adjust the date. Holding down the arrow button will fast forward. Use the DATE/TIME to move to the month and day, with the arrow buttons you can adjust.
All this is in the Instruction Manual. If you don't have one, go to the OMRON website and download one.
http://www.omronhealthcare.com/product/manuals.asp
SOURCE: Our Omron BP 755 is
My first concern, is how do you know it's reading high? Did you compare the reading(s) with one taken in your doctor's office? If that is the case, it may need to be re-calibrated. In which case, only the manufacturer can do that, as it has to be certified as accurate. Most manufacturers do it at no charge or a small charge, plus shipping. If you are relying on the reading you take at home, then it is well worth it to have it re-calibrated.
Hope this helps you. Please let me know.
SOURCE: where is omron bp monitor service center in india
call rehman on mobile no: +91-8754414889 for all your query of omron or other make of blood pressure monitor service problems
