SOURCE: XEROX PHASER 6180 LASER ERROR
That is a laser fault. You should have a 1 year warranty from Xerox on that product. Call 1-800-835-6100 have your serial number ready.
SOURCE: Color Printer Xerox Phaser 6180 Black Background Print out
Try the link below. If the toner is leaking from the cartridge return it to shop were you got it if it is damaged.
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=466,E=0000000001344030351,K=1906,Sxi=11,Case=obj(1307)
Niallbt
SOURCE: Xerox Phaser 6360 Black Toner prints Light Grey
I have had to repair a few of these. Take off the sides and back of the 6360. You'll see the hoses that feed into the laser. The black one becomes unplugged from the laser. All you have to do is plug it back in. The next step can be kinda messy. Take out the black toner cartridge, and spin the motor backwards. You'll know you're going the right way because it won't turn the other way. Cycle the gear where the toner sits for about 2 revolutions. Reassemble and you should be good to go!
This thing took me 6 days to figure out the first time. Haha!
Please vote on my solution! Thanks!
SOURCE: what's wrong when my phaser 6360 prints grey
I had this, had to call service engineer who re-fitted a loose circuit board inside printer. Not sure which one because I was not here at the time. If you are confident enough, and want to look for this yourself and push in all boards - be sure to disconnect from electricity supply first.
SOURCE: Xerox Phaser 6180 MFP-D password
The default password is "00000"
If this password does not work you can follow the following to reset it:
NOTE: There will be no confirmation message during or after the machine's power on sequence. However, if the procedure was performed correctly, the password has been reset.
