SOURCE: wireless mouse not working
We had the same problem and just found this solution, we don't know how long it will work for!
http://www.eggheadcafe.com/software/aspnet/29649087/usb-mouse-wireless-proble.aspx
hey - i think i actually found the answer.
there is a reset button on the bottom of the mouse.
and there is a reset button on the receiver that plugs into the USB. click them both and vuualla! - it works again....
we'll see how long this lasts.
(most blogs tell users to just exchange the set, it's poorly designed)
good luck -
SOURCE: Logitech wireless mouse and keyboard
Normal
0
Press the Receiver button (and the lights will start
flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT
button on the back of the board to connect the keyboard to the
receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button
on the back of the mouse to connect to the receiver. Then they
should work okay.
Hope this helps. Bud
SOURCE: Microsoft Wireless Notebook Optical Mouse 3000 help
I had the same problem.
Press the button on the underside of the USB, the green light will flash. Now press the reset button on the underside of the mouse. Your mouse should now work.
SOURCE: the wireless mouse works but the laser 5000
press connect on the wireless device...let go and then within 5 seconds press the button on the bottom of the keyboard. Repeat the same steps for the mouse whther its working or not. The problem usually is that the keyboard and mouse are on the same "Wireless Channel" and only resyncing them puts them on a seperate channel, hope this helps.
Erick
SOURCE: Im haveing trouble with my wireless microsoft
On the adapter there is a small red button. This button must be pushed, then the red button on the bottom of the mouse must be pushed. The mouse light should blink and you should be able to use it.
