20 Most Recent
Microsoft Wireless Laser Mouse 5000 Questions & Answers
Intermittent cut out. sometimes my mouse will just
It can be a Hard disk low space problem. Check your windows disc/partition free space and try to avoid leaving less than 10 gb of disk free space.
Check the Virtual Mem settings and if you have enough free space, manually set more room like 4gb on each partition/disk.
Can be a hardware...
Hard diks error problem - checkdisk
RAM Memory - Check mem
current (short circuit) or power supply proble
a device driver not working properly (try disconnecting new hardware and resetting windows to test.
can contact me at 573006230050 Whatsapp for direct help.
10/5/2018 6:25:25 AM •
Microsoft...
Answered
on Oct 05, 2018
Pairing code for Microsoft Wireless Laser Mouse
Not really a code, just first press button on top of your receiver and then the button on the bottom of the mouse. The receiver LED should stay green when they are connected. If this does not happen check that you are using IntelliPoint Mouse Software. See more:
https://answers.microsoft.com/en-us/windows/forum/windows_7-hardware/microsoft-wireless-laser-mouse-5000-v10-model-1058/692bf1f8-ce34-4937-8c8f-a78cff379787?rtAction=1483615029455
1/5/2017 11:26:21 PM •
Microsoft...
Answered
on Jan 05, 2017
It wont start working
Try to plug it in a different USB port. If the problem persist, try it on another computer or laptop. If it still makes the same problem, you will know it's because of the mouse.
1/5/2014 8:58:50 PM •
Microsoft...
Answered
on Jan 05, 2014
It stopped working, the keyboard
When you change batteries you also need to reset your mouse and the receiver.
Back on your mouse is a little connect push-button to reset your mouse.
Eventually also push the black button on the top of the receiver.
This will hopefully help.
Regards
9/7/2011 4:54:05 PM •
Microsoft...
Answered
on Sep 07, 2011
How do I open the
Hello cmaryclaire,
If you look at the under-side of the mouse, you should see a rectangular area (similar or the same as the picture below) with a small clip. All you should need to do is use a finger, push on the clip and lift. This should reveal the battery compartment.
5/25/2011 5:24:32 PM •
Microsoft...
Answered
on May 25, 2011
Mouse movement is wierd.
try update the wireless mouse driver. you can download the latest wireless mouse driver from the manufacturer's web site
3/23/2011 11:25:37 PM •
Microsoft...
Answered
on Mar 23, 2011
It says my usb thing has malfunctioned???? help
Follow the steps given below to refresh USB ports.
1. Right-click My Computer icon on the desktop, and then select Properties.
2. Click the Hardware tab.
3. Click the Device Manager button.
4. Click the plus (+) sign to the left of Universal Serial Bus controllers.
5. Right-click the device listed under Universal Serial Bus controller and select Uninstall.
6. Click OK to confirm the removal of the device.
Please note, repeat Steps 5 and 6 until all the devices under Universal Serial Bus Controller are removed.
7. Shut down the computer.
CAUTION: Ensure that the Shut Down option is selected, instead of the Restart option.
8. Wait for 5 seconds and then restart the computer. When the computer restarts, a "Windows has detected new or added hardware" message window will open.
The above steps will refresh the USB ports.
Now connect the USB devices like mouse, video camera, your external usb hard disk...usb hubs...whatever you like and the drivers should install automatically.
Tip: It is always recommended to connect the main usb devices at the rear end usb port, as they require more power to initiate.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
2/22/2011 4:41:36 AM •
Microsoft...
Answered
on Feb 22, 2011
