IT CAN BE THE TENTION SCREW ON THE BOBBIN CASE SOME TIMES THE BOBBIN SCREW CAN LOOSEN SO WHAT HAPPENS THE THREAD GET TANGLE UP IN THE BOBBIN CASE AND THAT BECOMES A PROBLEM 1-YOU CAN TRY AND TURN THE SCREW IN THE BOBBIN CASE TO YOUR RIGHT JUST A LITTLE FROCTION EACH TIME YOU DO THAT TRY SEWING SEE IF THERES ANY CHANGES 2-MAKE SURE YOU TREAD THE SEWING MACHINE RIGHT AND CHECK THE POSITION OF YOUR NEEDLE SEE IF IS SET CORECT CAUSE IF THE NEEDLE IS NOT SET RIGHT THAT CAN ALSO BE THE PROBLEM OR MAYBE WRONG NEEDLE. REMINDER START 1- CHECK NEEDLE 2-CHECK SEE THAT THE SEWING MACHINE IS TREADED RIGHT 3-THEN TRY THE SCREW ON THE BOBBIN CASE 4-CHECK SEE IF THE SEWING MACHINE NEEDS OIL.
SOURCE: My bobbin thread keeps coming to the top of my
With the embroidering, some of the bobbin thread is SUPPOSED to show on the top of your embroidery-the machine isn't doing anything incorrectly. You'll need to thread your bobbin with the same thread as you are using with the top. I had the same "problem" when I first got the machine and took it to a wonderful local technician whose helped me with a lot of things who informed me that this is perfectly normal on embroidery machines.
