Electrical Supplies Logo
Gary Wolfer Posted on May 18, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Don't seam to have spark 210 cc power ease engine checked oil level also bypassed switch
Chuck Graybill
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 104 Answers
  • Posted on Jun 03, 2019
Chuck Graybill
Expert
Level 2:
New Friend:
Cheetah:
Answers
104
Questions
0
Helped
40360
Points
206
Did you bypass the on-off switch or the low oil level switch? Try opening the oil level switch wire.
5 Related Answers
Anonymous
  • 174 Answers
  • Posted on Jul 05, 2009
SOURCE: 6.5 honda on pressure washer have no spark.Cleaned
Check the coil is gapped properly. Is the plug wire attached to the coil. Is the coil working.
A Miller
  • 8404 Answers
  • Posted on May 13, 2010
SOURCE: how can i check the transmission oil level?
Transmission and engine share the same oil.
MrJunk
  • 13 Answers
  • Posted on Jul 03, 2010
SOURCE: I have a Coleman Powermate pm0545007 generator
there should not be pinched wires...
if you mean "how do I bypass the low oil SENSOR" then the answer is to just disconnect it and tape up the end or snip it off in a location where it won't ground out...the way these engines kill the spark is by grounding the cdi coil wire...so fix that pinched wire and youre probably good to go...dont disconnect the low oil sensor unless its causing trouble....having low oil protection is good and might save you from blowing an engine
Asbestos 56
Ron
  • 195 Answers
  • Posted on Nov 18, 2010
SOURCE: engine will not start. no spark. oil level is
There may be a engine control switch on it. It will be on the engine somewhere. it is differnt then a circuit breaker on the outlet panel. It also could be a bad ignition module.
Anonymous
  • 7 Answers
  • Posted on Feb 20, 2011
SOURCE: diagnostic check warning light on.
hello i have a spider gtv on a 99, as the engine gets upto temprature the warning light flashes and once the engine is hot the oil light stays on, only on tick over. i have changed oil pressure switch. still the same though.
I have A Steele 3250 watt generator 196 cc OHV engine gas powered and it wont start.what do Can l do too fix it?
turn on the ignition switch
check and bring the oil to the correct level
check for spark
check choke operation
check low oil level switch is operational
Homelite hgn 0960a generator wont start no spark
Change Spark Plug. Check The starting Switch with a Multitester if it have continuity.Start it again and check Spark with the spak plug unplugged and with the crankcase check the spark.
Check the oil level. almost all the new and modern generators have included an oil alert gadget that cut off for saving the engine.check oil level and refill if it need.start it again.
On a Generac model 1646-2 generator is the oil level switch normal open with full oil level.
I don\'t know, but change the switch or bypass it. They give plenty of problems & motor would start sometimes & not others.....Check the oil & rely on old style tech. I bypassed the switch on both of mine.after they gave problems & wouldn\'t run when needed....I only got a second one when I needed power & the switch was the only thing wrong ( I found this out too late.) & ended up with 2....
I have a Champion generator 6000 starting watts modle number 41115 starts and runs for a few minutes then shuts down , has fresh gas and new spark plug.
Is the oil level good, does the low-oil cutoff switch work properly? Try bypassing the aforementioned switch to see if it fixes your woe.
BRAND NEW ENGINE. USED THE FIRST TIME DURING HURICANE IRENE. OIL LEVEL IS FULL, USED REGULAR GAS AND HAS BEEN CHECKED FOR IMPURITIES. PROBLEM IS THAT AFTER 32 HOURS, THE ENGINE WILL ONLY RUN FOR 15...
Hi, if it re starts immediately and requires choking it is a fuel related problem. If it has to sit for a while before restarting, check for lost spark as soon as it stops. If no spark make sure the unit is level and oil is full when sitting level otherwise the oil cutoff switch will shut it down. If oil and unit levelling are ok and there is no spark the cdi unit is most likely faulty. Hope this helps, regards Phil.
The motor wont start
This could be a few different things. 1. Check oil level, if your machine is equipped with a low oil sensor the engine will not start if oil is low. 2. Check the spark plug, remove it and place it against something metal and crank the engine over while looking at the spark plug to see if you have spark. Don't hold the plug because you will get a shock. 3. Check the carburetor, remove and clean. Check the air filter, make sure its clean. If these steps don't work let me know.
2helpful
Could not start engine but headlight can be turn on no problem.
Hi and welcome to FixYa, I am Kelly.
Headlights are on a separate circuit from the ignition.
What must happen for ignition.
1. Engine crankcase fully serviced with oil (Low oil level sensr will ground ign. if level is low)
2. Operator sitting in seat.
3. Clutch brake pedal fully extended (in some cases fully depressed)
4. PTO clutch disengaged.
5. Key switched to start or run
Check your ignition spark. If you don't have a 2nd person to help you get a paint stick and staple 2 wires on it with a small gap so you can hold it. Attach one wire to the spark plug cap and attach the other wire to any ground. Just make sure that the wires and the gap are far enough away from you so that you do not get zapped. (wires you use can not be chaffed!)
(Ignition is not fused)
If you do not have spark... first disconnect ONE wire from the oil level sensor and try again. If you have spark.. clean the low oil level sensor INSIDE the holes.
Still no spark you will have to jumper safety switches one at a time until you locate the faulty switch. (Pedal, Seat, PTO)
If you need a wiring diagram I need your mower model number.
Thanks for choosing FixYa,
Kelly
May 07, 2011 • Garden
I have a Coleman Powermate pm0545007 generator with a B&S OHV model 200000 engine. It has always run fine, but after running it for about 3 hours last week, I can't start it. It has no spark. I...
2helpful
2answers
My 5250 watt Power Back generator will not start, and their is no spark at the spark plug.
Have you check the engine oil level?If it is down on oil you won't get spark because of the oil level switch shutting the ignition down to protect it's self.
Top Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Electrical Supply Expert? Answer questions, earn points and help others
