Clean rollers in the ADF (automatic document feeder) with methylated alcohol for quick fix or replace the roller assembly
PN: 5851-2559 and seperation pad PN: Q2665-60125
I'm not sure can I help you, I had same issue with logitech, I couldn't solve issue, until I found program (app) that had option to connect them, search on hp for application. Logitechs one is called SetPoint.
Your Eager Beâver model number is 600016. There are many prefixes and suffixes. The one below I used when repairing a similar problem with my Mac 110 (earlier version of your saw). Both the automatic and manual oilers work now.
I get the best results for new McCulloch parts here: This is a little complicated so I am going in small steps. M & D Mower http://www.m-and-d.com/parts.html Click “Illustrated Parts Diagrams ON LINE” Click “Click Here for Parts Lookup” Changes to “Select OEM” Window reads “Briggs & Stratton ▼” Click the arrow and select “McCulloch Power” Click “Gasoline-Powered Chain Saws” Click “18-600016-27” There is a shipping and handling charge from M & D (about $9) if all parts in same container only one fee. See “General Assembly” print Item 33; pn 85557; Oiler body; most likely failure, on bottom of Item 31 Item 31; pn 217755; manual oiler piston; It pulls through the top of the tank. I ordered a new one but got Item 36, they were the same pn, I complained, seems they fixed it. See “Powerhead Assembly” print Item 07; pn 219989; oil pump assembly Item 04; pn 217168; pump/bar pad connector (hose) Item 05; pn 217167; pump/oil tank connector (hose) The new one was to long, I used the old hose. I have an earlier model. Item 17; pn 110653; O-ring If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH Lou
Start the computer in "safe mode" (press F8 when it's booting). Then remove the driver and reboot. Re-install the driver and then be careful about the resolution you pick.
Dell 8100 is a tower and you can replace it with any video card and get better performance with a replacement.
PN typically means Part Number so that is probably correct. Also, if you call Dell support, if you give them the pc serial number, they should be able to tell you the part number of the video card. If it is out of warranty, just explain to them you just need the part number
I have done this before and gotten the info I needed.
