SOURCE: How do I change the stiches?
You can do all of these stitches by using different combinations of your stitch selector, stitch width and stitch feed knobs, for instance, on the panel I can see on your machine:
http://www.jo-ann.com/joann/product/images/52659.jsp?CATID=cat3122&PRODID=prd11333
Stitches 1, 2 & 3 are straight stitches, centered, left and right. Really basic stuff, not different stitches at all. 4,5,6,7 & 8 are zig-zag stitches of different widths. 9 is the widest zig-zag (no. 8) on a finer stitch length, etc...
I think you should try and get an instruction manual for your machine. After a lengthy search of my usual manual sources, I've determined that that this may not be so easy. I think you should contact White on their 800 number and let them try and help you... 1-800-331-3164.
If you found this helpful, please vote generously as I receive nothing other than acknowledgement for my time.
SOURCE: Machine sews zigzag although stitch is set at 0 for straight
It must be a design flaw- things don't always last like they are supposed to. I would personally check the physical reason it is not responding... knowing what it would take to make it stop moving- or whatis causing it to. *perhaps the switch isn't working to stop it- or the mechanism that controls it is worn down. If it was new- I'd return it- but there are only a few options at this point.
SOURCE: how do i use the zigzag stitch on my bernina 830
Hi, open the top cover and if you watch what goes on inside from the top when you move the top change lever you will see part of it goes through a fork or U-shape part. This part is probably stuck and needs some oil. After oiling and working it back and forth a bunch eventually it will start snapping into the notches its supposed to. I beleive then you will have your zigzag back.
Either that or you have the stitch width set on zero.
SOURCE: Setting Machine on Different Stich Patterns
Turn the dial for stitch length so that the black line that separates the stitch length numbers from the buttonhole functions is in the 12 o'clock position. This engages the gears that operate your red stitches.
