Problem corrected, my crypto on the Stratix was corrupt
SOURCE: remove a ACE from an ACL using CLI
Sure thing:
First to enable the web interface, try command:
ip http server
Also try:
ip http port 80
That will enable it on the default port
As for the ACL's I looked at the documention and I believe the syntax is to put a deny in front of the command and that will remove it.
Of course the GUI will be easier to deal with
The manual can be downloaded from:
http://support.dell.com/support/edocs/network/pc6024/en/index.htm
SOURCE: Stratix 5700 will not connect using the Gui interface
is it too much to say.
Stratix 5700 Industrial Managed Ethernet Switches/.
what are you doing.
the manual covers this, did you read that first.
as we all do on any switch first bough or setup.
no 2 switches are the same, so..... (in basics sure)
but not the details.
