My whirlpool WED4910xq0 heating element never shuts off/cools down when in cycle. It continuously heats until it blows the thermal fuse. It does turn off when the door is opened or when timer reaches "off" position.
SOURCE: Heating element stays on after door is opened
possibly something grounding the element to the housing. what brand of dryer do you have? GE/Hotpoint dryers are good at allowing things like underwires from a bra to get into the element area and ground out the element. or possibly the element has broken and the broken end has fallen against the housing. hope this helps
SOURCE: Whirlpool Electric Dryer Model LER8858EQ1 TYPE NO. 180-0
Based on the information that you provided, if you open the door in mid-cycle and the motor shuts off, but the element stays on, this will stop the air flow through the dryer and the element. The element temperature will rise drastically because it is not being cooled. Subsequently, to prevent a fire, the thermal fuse will open, shutting the element, and in some cases the motor, down.
A heating element gets its power from the timer, through the cycling thermostat(s),and to 1 side of the element.
When the motor starts, power is passed through the centrifugal switch in the motor, through the hi-limit thermostat and the thermal fuse to the other side of the element.
There is no ground wiring involved in the heat side of the dryer.
1. An element can stay on because it has broken and fell against the metal tube where it picks up a ground. Solution is to replace the element.
2. The centrifugal switch mounted on or in the motor can fail to open when the motor stops and allow current to flow through it
until the points in the timer open up, breaking the circuit.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
SOURCE: Maytag dryer heating element does not turn off when tumbling stop
your timer is bad,the cost of a timer is close to a new dryer.
SOURCE: whirlpool leb6000pq1 not heating
Thermostat controls heat. There is also a
motor centrifulgal switch, in the element
circuit, that the motor closes to insure
the motor is turning. Try another heat
setting. There is more than one
thermostat. You may have blown the
'thermal fuse' too, which requires
replacement. The elecment has a contact in
the 'timer' circuit too.
It is possible that your element has
failed also.
Tripped high limit. Must clean the lint
filter and the exhaust vent tube and all
the way in to the dryer. Hot air exit is
restricted.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: Heating element stays on when dryer is off.
I would advise to inspect the high limit thermostat. this device may be defective. this will cause the element to continue to operate when the unit is off as well. If the thermostat is operating correctly, replace the timer.
