Home Logo
Thomas Boehm Posted on Apr 30, 2019
My brand new hardwired kidde is sounding fire when I turn the circuit breaker on and doesn’t stop when I puts the middle button
Gunny Skare
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Jun 15, 2019
Gunny Skare
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1161
Points
6
You need to check wiring configuration, you may have a faulty device/devices.
5 Related Answers
Anonymous
  • 4 Answers
  • Posted on Feb 02, 2008
SOURCE: kicks off circuit breaker
make sure your breaker is high in amps, at less 50 amp breaker
Anonymous
  • 833 Answers
  • Posted on May 27, 2008
SOURCE: humming oven clock
You'll need a new clock motor or clock unit. Once these units begin to hum, they must be replaced. Parts are available on the web, through supply stores or Sears Parts.
Paul James
  • 95 Answers
  • Posted on Jun 10, 2008
SOURCE: Thru-the-wall air conditioner won't turn on
Check for power at the plug in, if it's got power take it back under warranty.
Frank Chen
  • 330 Answers
  • Posted on Jul 06, 2008
SOURCE: All igniters sparking
the only thing which I found is after I clean the burners, maybe some dirt in.
Anonymous
  • Posted on Oct 24, 2008
SOURCE: Kenmore 90 series model 110 60902990
There is a thermal fuse in the back of the dryer, its usually white plastic, usually with 2 lite blue wires going to it.its probally blown...you can check it with an ohm meter......but if it is blown make sure you check the vent hose to make sure it aint kinked off that usually causes them to blow. if it aint that, be sure to make sure the heating element aint shorted to the heater box.or the thermostats aint stuck....the thermal is a safety feature and something caused it to blow
In new 3-alarm system just installed by electrician the alarms issue 3 long beeps and "FIRE" about every 10 minutes. Kidde is not available to help. Can you?
I think it could be one of three things.
The electrician may not have installed the back-up batteries.
The electrician may not have turned the primary power to the detector circuit on when he completed the work and now the battery is depleted.
The electrician may have tied the the detectors into a switched circuit which does not apply constant primary voltage.
Hopefully you can contact the installer to troubleshoot his work.
My Kidde Frynetics 1275 smoke alarms started going off intermittently. (Slower than when there has been smoke in the house from the oven). THere was no fire and no smoke. Not sure why?
Make sure to only use a brand name alkaline 9 volt battery. Don't use a used battery or a dollar store battery (bargain store). Then press the test button for 10 seconds to reset this unit and any more down the line.
I have a malibu ML 88T low voltage transformer. It was working fine and I saw the manual on/off and turned it, (i should have left it alone). The lights did not come on, so I turned the manual on/off...
You can do it yourself.
Anybody that knows 'hardwired' and observed timer is making humming sound can wire up a timer.
If M88T timer dial is not rotating, but power pack is making humming sound, then that says timer is receiving power but clock motor has gone bad.
There are no replacement clock motors for power packs.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
To wire a new timer:
Click circuit breakers until the humming sound turns off.
Turn breaker back on to confirm that humming sound is associated with that breaker.
Buy a tester at local hardware and ask them how to use it.
Tester will give you assurance that power is off when connecting new timer.
Outdoors: put down dry boards to stand on, never stand on bare soil or wet/damp surface, don't touch anything metal and don't hold metal screwdriver in mouth while working on electric circuit. Wear gloves if you want. And don't sweat.
With 120volt circuit, as long as you are not grounded, which means that you are not touching soil, or anything that grounds back to soil, then you will not get electrocuted. You can get shocked only if power is still turned on at circuit breaker, and it will be surprising, but it won't kill you as long as you're not grounded. All electricity goes back into the earth to complete circuit.
Open the box where timer is hardwired.
Use tester on black wire. To confirm power is off.
Typical 120volt circuit: Black wire is Hot and carries voltage. White wire is neutral and completes the circuit back to ground. Bare copper wire is ground and serves as redundant safety.
Old 88T timer will be wired black-to-black, white-to-white, and green-to-bare copper.
Take photo of wiring to avoid confusion. Post photo on flickr and add a comment with link to photo for another pair of eyes on situation.
Cut off end of new timer wire, strip insulation with knife and attach wires same way previous timer was connected.
http://waterheatertimer.org/How-to-twist-electric-wire.html
To install ordinary 120Volt outlet so timer can plug in: Buy outlet from hardware: Black hot wire connects to brass-colored screw, white neutral wire connects to silver-colored screw, bare ground wire connects to green-colored screw.
Open following link to see basic circuits:
http://waterheatertimer.org/B220C.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
5helpful
I have a series of 7 kidde ionization smoke alarms model 1276 hardwired with battery back up. The problem is all of the alarms will go off during the middle of the night for no apparent reason. The only...
Don't know for sure, but if your smoke detector is more than 5 years old, than you have to purchase new one (that's their average lifetime). Take a look on amazon: Amazon com smoke alarm . I hope I have helped. Cheers
3 new Kidde i4618 smoke detectors were put in last week. Last night one of them began chirping. I went to the store and bought brand new batteries and replaced them and tested the units which all worked....
smoke detectors work by smelling the air across a radioactive anode which upsets the electronics and sets off the alarm
it can be set off not only by smoke but by heat and gasses in the air
the new and better product is a photo electric detector which alerts earlier and can be installed connected to each room and into the house power or they come with a 10 years lithium battery
It could be a faulty unit so take it back for a warranty exchange unit
2helpful
The unit was not chirping but I decided to replace the battery. After I put in the new battery the unit is now chirping.
Replaced another battery,brand new battery a must,press the test button,by letting it goes off like 30 or 40 sec. so it will detecting the new power of the battery.The chirping,will stop.
Kidde pe 120 photoelectric sensor smoke alarm emits 3 "beeps" with a pause and then repeats until the 9vdc battery is removed. The house is not on fire and the 120vac power is connected. What might be the...
The 3 beeps, known as temporal pulse, is indicative of an alarm condition. If it stops without a battery, then the unit either does not have power or is otherwise defective.
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
