Hey hi Barry I am not sure if you are on a phone or
Computer either you can enhance the pictures or type by going into settings on your phone
Accessibility.
Magnification Gesture needs to be on
Font size needs to be set large
Or Display Size needs to be set large or XL.
Or if it is on a web site if you tap your phones screen
And spread your fingers it will enhance the display .
Now if that doesn't work you can go to the library and
Have it printed exlarge.
You don't see what kind of computer manual you need but the best thing to do is to go on line and download an electronic copy of the manual, usually from the manufacturers,
Once you have that you should be able to read it with a pdf reader such as adobe, (or whatever reader format the electronic file requires).
With electronic readers you can enlarge the font to suit yourself.
Good luck
SOURCE: is there an on user
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/other_powershot/powershot_sx110_is#BrochuresAndManuals
SOURCE: need larger typeface for easier
there are a couple of ways you can get larger font. On your keyboard you may have a "zoom" button with a +(larger) and -(smaller), where you can adjust your font up and down as necessary. If you have a tools icon at the top right of your screen, might look like a gear, click on that and see if there is "zoom" in there, click on that and click on font size you need, again you can adjust up and down as required. You can also click on "start", lower left of your screen, find "control panel" and click on that. In your list(icons) you should see "adjust font size(DPI) at upper left of your screen. Click on that and then click on continue. You should see "larger font size" with a empty circle on the left. Click on the empty circle to select, or, you may want to click on "custom DPI"(lower right) to do a custom size. I recommend going with the first option and resatrt for it to take effect. If this is not the size you want, you can then try the custom DPI. Make sure you restart after each change of font size. If you figured out you zoom, you can now still adjust the size there also.
Testimonial: "Thank you. I was able to zoom with the plus sign but I needed to use ctrl with it to do so."
