SOURCE: pop up box appears periodically
try bringing up the menu, and see if there's an option "factory default", and try that. you didn't mention what button on the remote you press to get rid of the popup, or what feature you are turning off to get rid of the popup,
SOURCE: Vizio P4 Plasma green blotches
OK Service tech came out last night (7pm) and repalces the main board and updated firmware to the latest. he said the red/green snow is a fairly common problem with the early units (mine was a july 2006 build). Picture is fine now but we will see how long the fix lasts. Main board was definitely the issue, firmware upgrade was prob just because they could.
Keep in mind this unit was OUT of warranty. I find it refreshing that Vizio took responsibility and set up a service ticket for a 16 month old unit. Not that they shouldn't last a lot longer but they could have just said tough luck.
SOURCE: menu keeps coming on .
First check for a short in all power semiconductors diodes, transistors, SCR, etc. Replace defective parts. The FBT coould also be defective. Check the voltage on each of his pins.
TV Repair
SOURCE: phillips plasma tv. Settings menu pops up all the
Philips.com should have a software upgrade for your TV to fix the problem.
This is a common problem with Philips TVs and they have made upgrade software to address the problem.
Go to the Philips web site and all the procedures for download to your TV will be there. The only thing you will need to this is a USB memory stick. Download should be FREE.
SOURCE: Menu Screen keeps popping up, interrupting cable stream on tv
You have it in the demo mode go into menu and turn it off.
