Change language to English in Sony Bravia KDL40HX750
Yes, it is possible to change the menu language.
1.Press the HOME button, then select[Settings] at the bottom of the screen using thebuttons.
2.Select[System Settings] using thebuttons, then press thebutton.
3.Select [Language] using thebuttons, then press thebutton.
4.Select the desired language using thebuttons, then press thebutton.
To return to the last viewed source, press the HOME button twice.
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
SOURCE: sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
SOURCE: Bravia KDL-46VL130 TV: Our Sony KDL-46VL130 picture is streaking and some...
That symptom may cause by the main board or t-con board, I suggest you do software up grade first.
SOURCE: sony bravia kdl 46s4100 no picture
it sounds like your back light might be going out. You might be able to fix this by installing a new backlight inverter board.
SOURCE: slow moving image sony bravia KDL32M3000
This is actually a common problem with this model, and its surprising that it really does look like a video board (BM board) problem. It is actually a problem with the panel itself.
Here is the fix:
http://www.youtube.com/watch?v=9UrTVEC5LkA&feature=related
This guy was kind enough to post it. I recently did the repair on a KDL-32M3000 and it worked like a charm. Took surprising long, but worked like a charm. I didn't have a 10 Ohm resistor laying around, so I used 2 x 4.7 Ohm resistors in series.
