SOURCE: Model TBX21KLK water pooling UNDER vegetable bins
Your evaporator coils frost up in normal use
and every eight hours or so the entire unit shuts down and the defrost heater
comes on to melt the frost. This cycle last about 20 minutes. The melted frost
drips into a drain pan and through a drain tube to the drain tray under the
freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end
because it drains too slow because it's stopped up at the lower end in the
evaporator pan under the unit at the floor. It can get dust and mold in it. Once
you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing
it out with hot water and clorox may help.
Make sure it drains quick enough to prevent
refreezing. . The drain should be located below the evaporator coils on the
lower back of the freezer.
SOURCE: Water leaks in from freezer. eventually filling
Maybe, Your evaporator coils frost up in normal use
Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing
to prevent refreezing. . The drain should be located below the evaporator coils
on the lower back of the freezer
SOURCE: Water leaking from inside F&P frig model
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
SOURCE: water draining into frig
heatman101
SOURCE: refrigerator thermastat set to 37 degrees but
i have never seen the problem
my idea is the thermostat is bad. but won,t both of them be bad.
you try to check the damper motor swithch and damper motor
good luck
