Music Logo
Sean Conroy Posted on Apr 20, 2019
Dropped my Roland micro cube GX and it won't power up at all what could be the problem
Doug Caskenette
Level 1:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 25 Answers
  • Posted on Sep 27, 2019
Doug Caskenette
Contributor
Level 1:
Greenhorn:
Night Owl:
Answers
25
Questions
Helped
13489
Points
77
Check the fuse for power because it could have broke when it was dropped , check also for loose wires and bad ground wire attachments.
Steven Sauerwein
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Apr 30, 2019
Steven Sauerwein
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2895
Points
9
The most likely problem would be wiring. By dropping it you loosened or disconnected a wire.
2 Related Answers
rabbitbrains
Rabbit Brains
  • 575 Answers
  • Posted on Apr 30, 2011
SOURCE: Roland micro cube dosnt power up
Check the fuses. There is probably one on the outside of the amp and some inside the circuit board.
Fred Yearian
  • 5603 Answers
  • Posted on Jul 14, 2011
SOURCE: roland micro cube fuse replacement
If the fuse blew, it is for a reason requiring repair. Troubleshoot and use a 40 watt lamp in series to limit current until cause of fuse blowing is found and repaired.
Roland Cube 30 Bass Amp won't turn on?
1. Check the power cable and ensure it is securely connected to both the amp and the power outlet. 2. Check the fuse and replace it if needed. 3. Check the power switch and ensure it is in the correct position. 4. Check the battery (if applicable) and replace it if needed. 5. If the amp is still not turning on, contact Roland customer service for further assistance.
2answers
I dropped my Roland Cube GX last night from the ground when that happens what are the common problems is the reason it won't power up from being dropped and impacted
Unfortunatly the impact from a fall can lead to numerous problems ranging from a broken fuse to a disloged power supply to a cracked board. I'd suggest taking it into your nearest Roland authourized service center to get it checked out. If you're not trained in electronics you can do more harm than good poking around inside the amp. https://www.roland.com/us/support/service_repair/service_centers
Roland Micro Cube Amp fuse blew out. How do you fix it?
have a look here:
http://www.ehow.com/how_8698510_fix-roland-cube.html
although it doesn't mention the fuse you will probably find it. Sometimes there is a fuse access on the outer case.
Roland micro cube fuse replacement
I need to replace the power push button, but do not know what part number it is. Trying to get it ordered through Mouser, but there are too many listed. All I know is that it's an Alps switch, and it reads...
HI,
I've just had a Roland Micro Cube amplifier in for repair and it uses the same type of Alps switch you mention. ( It's also broken )
This is a simple single-pole latching push-button switch, so electrically, almost anything rated for an amp will be good enough.
Alps no longer make the same part, so you'll need to find something which looks the same and fits the original hole.
My repair is easier, because the replacement part doesn't have to match anything.
Graham.
Top Roland Music Experts
NOEL
NOEL
Are you a Roland Music Expert? Answer questions, earn points and help others
