20 Most Recent
Roland Fc300 Guitar Foot Controller Questions & Answers
None of my programs are receiving midi commands
I have a FC-200. I don't know by your post what you are trying to do but think of the pedal as a device that can alter a communication between two other devices or one device which transmits info which the pedal receives, alters and then transmits to whatever is on the receiving end. In this case your program. The pedal has to have sysex info transmitted to it or midi info such as a sequence etc. I use mine to control the parameters on my wind syth module. I go from midi out on the module to midi in on the pedal and from midi out on the pedal to midi in on the module. There is also a battery onboard that you might want to check that stores your pedals programmed parameters. Hope this helps.
Hi. Can I use the second pedal on my Roland BK5 to scale up the key one semitone at a time?
Yes, you can use the second pedal on a Roland BK-5 keyboard to transpose the key of the music that you are playing up or down by a semitone at a time. To do this, you will need to press and hold the second pedal while playing the keyboard. You can also use the transpose function in the settings menu of the BK-5 to adjust the key of the music that you are playing by a specific number of semitones.
1/5/2023 4:04:49 PM •
Roland Music
Answered
on Jan 05, 2023
I need a circuit diagram for a Roland MA-15D speaker please?
It's a Chinese made Roland and no service information is available as when a fault is found the main board is replaced, eliminating the need for service information.
I would check that it is a stereo out jack and not mono. If it is a stereo out, check that both input phonos work. If they do, replace the faulty socket or damaged pcboard.
11/17/2022 6:14:26 PM •
Roland Music
Answered
on Nov 17, 2022
MY Roland Handsonic's digital display is gone
Hell,
there is no display on your Roland Handsonic because the screen inverter or screen board panel is faulty. This has to be replaced for you to see your digital display again.
So its either you use it like that without the display or you take it to a repairer for fixing.
Take care.
7/11/2022 8:54:01 AM •
Roland Music
Answered
on Jul 11, 2022
