SOURCE: Washing Machine fills slowly how to change inlet valve
switch off power remove top switch off water and remove hose. remove inside pipe from valve - usually held by just a spring clip remove electrical terminals valve is just held with a couple of screws usually - remove these and valve will come away. put back in same order
SOURCE: roper washing machine mod# RAS8245EQ1
The problem is one of two parts. One is your water temperature switch or your hot water solinoid. To get to the back you must remove the hex screws on the back and then the panel is removeable.
SOURCE: Water is not filling up.
turn off water
disconnect fill hose from tap
examine screen inside hose end for 'muck' blockage
clean screen
reconnect hose
test washer
if no fill
replace water solenoid valve
note: cold water valve fails first, it gets most use,
if only using cold water, you can simply swap the hot and cold hoses at the tap, and swap the hot and cold electrical connectors on the solenoid valves, the hot solenoid is no the cold one and the washer can be used, cold only, for about as long as it has operated thus far..
SOURCE: Kenmore Washing Machine - no cold water coming in
most likely cuase would be the inlet valve
you would need the complete model number to make sure you get the right part for that unit.
SOURCE: I have a kenmore elite H3 washer. The cold water
Check the inlet valve solenoid wires for resistance with an ohms meter. The cold and hot solenoids should have close to the same resistance. My washer had a weak solenoid causing the hot water valve to close after 4 or 5 seconds. While checking the solenoid wires for resistance with the ohms meter, I noticed the cold side had 51 ohms but the hot side only 8 ohms. Hope this helps.
