SOURCE: Remote Codes for new Sony Bravia
0000 worked for my XBR4 using the remote called: Comcast Custom DVR 3 Device found here:http://www.comcast.com/corporate/customers/customer_support/remotes.html
SOURCE: Picture get dark than light
On your remote control, press the huge circle, which should be settings or menu, there, go on brightness, put it up to max if u want bright, and low if u don't .If the problem still happens, ask customer service to help, or return it!!
SOURCE: Screen too dark. Have adjusted brightness but still seems dark. Is this a sign of bub going bad?
Yes, time to replace the lamp. You can do it yourself.
SOURCE: Our Sony Bravia tv picture keeps going light dark
I have Sony KDL-32XBR9 and I have noticed a similar problem. When the picture is showing mostly black, for example during the ending credits of a movie, the TV will further darken the display. Once the picture lightens back up, the TV will adjust the brightness of the display back to normal. I just called Sony customer support and they indicated it was a firmware problem and they will be sending a USB device in the mail to update the firmware. Hope this helps.
