SOURCE: 4150sx finder erratic depth
I had the same problem last time I was out in shallow water (in less than 2 metres of water) and I suspect that the problem was weed wrapped around the transducer but won't know for sure until I take it out on the water again. I had another problem re water temp which I'll enter separately.
SOURCE: wire on depth finder has been piched, can tou
Yes, you can. I have done it several times. Keep the separated wires fairly short. You can pick the braided (shield) wire apart with a pin or such.
SOURCE: My depth finder loses its depth reading at about
You need to set the transducer lower. When at speed, the hull of the ship raises up out of the water and hence your transducer is probably not deep enough at these times to give a proper reading.
