Lands Phones Logo
N
NGA T LE Posted on Apr 07, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to add one more hanset to the base - Lands Phones
Don A
Level 3:
  • Lands Phones Master 4,499 Answers
  • Posted on Apr 07, 2019
Don A
Lands Phones Master
Level 3:
Answers
4499
Questions
5
Helped
1337488
Points
25829
Additional handsets must be registered to the base. Registration to the base requires specific key entries doubtlessly brand specific. A user manual may be helpful regarding such. Here is the procedure for Panasonic phones:
https://www.techwalla.com/articles/how-to-add-a-handset-to-a-panasonic-phone
Do you register each hanset on the main base unit?
only if the phone stops working then put it back on the main base and let it charge and that should take care of it. until the battery will not take a charge then you will have to replace the battires
1helpful
How do I fix base unit battery charging system not property working when I leave hanset on base unit automatic dead when I lft hanset for answer incoming calls?
It is highly likely that your battery pack needs replacing. If you have had it for more than a year and use it often then it is quite possible. You can buy a new one at radio shack online or search for one similar on ebay. Price is about 10 pounds though.
If you have more than one of these phones it may be worth while buying more than one as it will save you postage and might get you a discount.
Hope this was helpful
Batteries will not charge on phone
Try cleaning the two metal contacts o the base of the hanset and the the two spring loaded contacts on the base/charging unit. Use an alcohol based solution such as glass cleaner or surgical spirit on a cotton bud or piece of kitchen paper.
If that does not work it may mean that your batteries need replacing.
My uniden hanset stopped working. When I click on
Disconnect your phone from the wall and charger....Take out the Batteries and wait 2 secs...Replace batteries and recconnect phone ..see if this problem is still happening.
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances.
Heres a site for more help:http://mycusthelp.net/UNIDEN/supportkbitem.asp?sSessionID=&Inc=1093&sFilA=Product&sFilB=Model&sFilC=&FA=-1&FB=-1&FC=-1
(Copy paste to browser)
Detect phone problem
Have you checked to see if there is a channel selection on the handsets? Do you get any sound thru the noisy phones from the phone line when you try and use it? You may check and see if there is a frequency programming adjustment, the three hand sets may be on a different frequency harmonic and need to be programmed to the correct frequency. The one that works good is probably the one that came with the base unit. The base unit should have a sticker on it telling the frequency it uses. There is probably a way to program them thru the key pad. Get out the owners manual and see what it says. Good Luck, RAC
Need to clear out a used kx-tga270s handset
press function, initial setting, registration, deregistration, enter 335(deL) and then press Ok (right button on screen).
Once that is done press mute on the base unit and Ok on the hanset (right button on sreen)
1helpful
Let our Experts solve your "Panasonic tga101cs base will not play back messages The message is recoverable from the 3 hand sets" Problem
I've just got a 2nd system of 3 handsets (KX-TG1033, DECT 6.0). I have also the same sytem in my house. Is it possible to expand 3 new hansets (number 4,5 and 6) to my existing base unit?
3answers
Siemens Gigaset 4200
Hello, Yes this happens when you add a additional handset to the system when all the intercom numbers are full. When registering a new handset, it "kicks out" on of the other handsets when it registers. The only way to correct that problem is to default your base and register each handset again, one by one. You won't lose your handset settings, but you will lose your messages and greetings, so check them before doing so. To default your unit, get all your handsets and go to your base. Unplug the power from your base. Hold down the page/registration key on the bottom of the base and keep it held down while you apply power to the base. After applying power, keeping the button down, count to 20. Then release the button and get each handset. Register each handset, and they will number themselves 1 through 4. If you need additional assistance, service or need to purchase another handset or base (you can register each handset to up to four bases to increase your range, this is unique feature in the cordless industry), you can go to www.cordlessrepair.com for all your Siemens cordless needs. Good Luck ! Let us know how it goes, we have a testimonial page on the website for people to leave comments on the technical tips or assistance they receive from our technicians.
2helpful
Headset feature
headset base of the handset is short due to contact with water. open the hanset and cleanthe base with ctc
Top Lands Phones Experts
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
