Some symptoms that occur with Toshiba laptop mice include
jumping and vanishing pointers.
These situations have occurred after software upgrades have
been made.
The problems can often be solved by following basic mouse
troubleshooting methods.
Overall, Toshiba laptop mice contain the basic functions
characteristic of the USB variety.
Function
The mouse device is used to move, open, delete and
otherwise connect with items available on and through the computer monitor.
In Toshiba laptops and many others, the mouse pad replaces
the point and click USB mouse device. This enables the mobile computer laptop
to be more compact, portable and ready to use.
Features
The mouse pad on a Toshiba laptop is located in the
middle, directly below the keyboard.
The control buttons, both primary and secondary are situated
below it.
The primary key, on the left, represents the left-click
button on an USB mouse device.
The secondary key on the right represents the right-click
button on an USB mouse.
This button is used to pull up the short menu of an item
after selecting it.
Update Keyboard Driver
Many Toshiba mouse issues can be solved by updating the
driver.
The driver enables the mouse to function properly. Update
the keyboard driver first to increase mouse and keyboard device compatibility.
To complete this task, click "Administrative
Tools," accessible from the Start menu.
Next, click "Computer Management," and then select
"Device Manager."
Click the "Keyboards" expansion node to bring up
the list of installed hardware, and then right-click on the keyboard that is in
use.
If the "Update Driver" option is available, click
on it.
Otherwise, select "Properties," go the
"Driver" tab and press "Update Driver."
Device Manager is a useful tool to update, rollback or
uninstall incompatible drivers.
Update the Mouse Driver
Update the mouse driver by following most of the
instructions in the above section, "Update Keyboard Driver."
However, after selecting "Device Manager," click
the expansion node next to "Mice and other pointing devices."
Select the current mouse device in use and right-click on
it.
on it. Otherwise, select "Properties" and go to the Driver tab and
Check BIOS Fixes
Some older Toshiba laptop models require BIOS (Basic
Input/Output System) fixes.
Most of the downloads are available from their website.
Since, the BIOS chip is the liaison between the hardware and
software, any issues should be addressed promptly.
Symptoms, such as erratic mouse behavior or the pointer
disappearing, are signs of a need for a BIOS fix or driver update.
Compatibility
Toshiba and most Microsoft Windows products are compatible.
This is vital when it comes to updating necessary drivers
needed for continual operating system function. The service packs they approve
of are listed on their website.
http://support.microsoft.com/kb/283658
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/navShell.jsp?cf=su_winos
