20 Most Recent
Toshiba Satellite Pro P300 Notebook Questions & Answers
Ecran tres sombre
Je l'utilise Google pour traduire , mais je ne suis pas s?r au sujet de la situation . Habituellement, quand changer ou remplacer une carte vid?o est l'ordinateur est en cours d'ex?cution jusqu'? alors vous devez acces le BIOS , d?sactiver la carte vid?o interne et l'ordinateur o? est la nouvelle carte . Je suppose que vous utilisez Windows , il ne sera pas ajouter pilote de la nouvelle carte , mais un pilote assez bon pour voir l'?cran. Ensuite, vous pouvez ajouter le pilote appropri? .
10/12/2015 2:06:13 PM •
Toshiba...
Answered
on Oct 12, 2015
Freezing lappy
Perform a system restore back to when the laptop was working properly. Then scan for viruses using Malwarebytes and TDSKiller. Also run system updates afterwards. Hope this helps.
7/2/2014 1:52:44 PM •
Toshiba...
Answered
on Jul 02, 2014
Windows Vista not reading discs
faulty dvd/cd drive by the sounds of things. replace the drive, you can get them off ebay cheep, then give it another go. that will tell u if its a hardware or software fault
12/29/2012 5:20:31 PM •
Toshiba...
Answered
on Dec 29, 2012
The satellite pro p300 will not start, power, charge lights come on, no beeps
Check the time if you can, doubt it since it can not display anything. This usually happen when:1. The memory card is bad, needs to be replace.2. The video card is bad. Since it's a laptop, then the problem is with in the motherboard.Sometimes when the BIOS battery is drained, it also stop the computer from displaying. To see the battery you must take apart the computer. And the last thing in the list is the monitor it self. Maybe the monitor got damage some how and it won't display anything. To troubleshoot, I recommend you start with the memory, and since the computer must be 64 bits, it needs 2 memory card of at least 2gb. each stick, if one of them is damage and both are still connected to the motherboard, the monitor won't display anything either.
5/27/2012 5:38:30 PM •
Toshiba...
Answered
on May 27, 2012
I 'VE GOT A TOSHIBA
Remove the laptop battery and unplug the ac adapter. Then remove the bios battery from motherboard. let sit for a couple of hours. this should do what you want to do.
9/1/2011 2:02:02 PM •
Toshiba...
Answered
on Sep 01, 2011
Hi i had to reformat
You will need to use the Toshiba recovery CD for that. Unfortunately, if you did not create a recovery CD when the computer is still working, the only way you can get one is to call Toshiba and purchase a recovery CD. Otherwise, you will need to buy a Windows CD as well and all the other application that comes with your computer and install them manually. I do hope this information helped.
7/18/2011 9:52:32 AM •
Toshiba...
Answered
on Jul 18, 2011
Toshiba Satellite P300 makes loud
If your experiencing beeps. Heres what you must do.
- Count the number of beeps
- Beware if its long or short beeps.
- Also take note if its a continous beep
Now after knowing this things. Go to this site.
BIOS BEEPSNow on that page you will see all the bios beep codes. Remember what you did before going to this site.?Take a look for that beep code and at the description of it. you will see what device or what problem you are facing right now.
Good luck, Hope i help. Please give me feedback regarding my solution.
7/5/2011 9:01:41 AM •
Toshiba...
Answered
on Jul 05, 2011
