20 Most Recent
Toshiba Satellite P105-S6197 Laptop Questions & Answers
How do I download and install micrsoft office 2010
MS Office 2010 is not a free program.
You will need to purchase a copy of MS Office to get the product installationkey.
For an alternative free program,
OPEN OFFICE is a full-featured officesuite that's compatible with Microsoft Office.
If you want Open Office you can download this free program.
Click on this link to download :-
http://www.openoffice.org/
8/21/2015 1:55:09 AM •
Toshiba...
Answered
on Aug 21, 2015
Toshiba 305 screen will not come on
if you shine a light at it can you see the graphics faintly?
If so the florescent tube or inverter has failed. you'll need to get it repaired.
3/12/2015 12:10:00 PM •
Toshiba...
Answered
on Mar 12, 2015
I Have a Toshiba , that the BOOTMGR is missing,...
This could be a very complicated repair. You should try some easy solutions first. A missing bootmgr means your computer cannot find the start up files on the hard drive. So maybe the hard drive is loose. Open up the computer and check the hard drive cables. Also check the Bio start up to be sure it is booting to the hard drive.
You can also try connection your hard drive to another computer and running disk repair from Windows or other hard drive repair programs.
Do you have any recovery or restore disks? try those.
You can try to install the trial version of
http://www.acronis.com/en-us/personal/disk-manager/#additional-features
On a computer and add your problem hard drive to it and try to fix.
Acronis support is great. You can ask them if any of their programs will rebuild your bootmgr file.
Else you need Windows disks. You don't need yours, just any that are the same version as what is on your computer. It is safe to borrow from a friend.
Windows Vista or Windows 7 installation CD/DVD
Boot from Windows Vista installation disc, select language and keyboard or input method, click
Next and choose to
Repair your computer. Then you will need to select the operating system that you want to repair. In the
System Recovery Options dialog box click
Command Prompt and type the following:
Bootrec.exe /FixMbr
Bootrec.exe /FixBoot
10/6/2014 8:07:03 PM •
Toshiba...
Answered
on Oct 06, 2014
My desktop screen is black (blank)
If you have a navidia video processor it has more then likely it went out or your monitor went bad. I had 2 laptops that the video processors went bad. They had the the navidia.
3/14/2014 12:44:25 AM •
Toshiba...
Answered
on Mar 14, 2014
My satellite lap top has 3 vertical lines on the
there is already a problem with the video card.. for most laptop, they have built in video cards.. so you need to have your laptop checked by a computer technician.. or it would be best to bring it to the manufacturer, so they can install the right drivers for the video card after being fixed..
6/28/2013 12:47:47 AM •
Toshiba...
Answered
on Jun 28, 2013
Turn safety mode
Try to restart the system and then keep tapping F8 key before windows logo appears. You will see a list of boot option, in that highlight the "start windows normally or normal mode" and press ENTER. Your system will boot in the normal mode.
4/23/2013 9:49:17 AM •
Toshiba...
Answered
on Apr 23, 2013
Toshiba Satelitte A500-17X Bios Update Fail
The bios is corrupted because it was not able to complete the download, or there was a power interuption corrupting the data, and finally the wrong file was downloaded. The only thing you can try is remove the main battery and disconnect the power supply from the laptop and press and hold power fot 60 seconds, then plug everything back in and try to restart the laptop, probably won't work.
2/4/2013 9:31:15 AM •
Toshiba...
Answered
on Feb 04, 2013
How do I take my pc back to factory settings
Restore Toshiba to Out of the Box Condition If your model Toshiba laptop has a Restore partition on the hard drive then follow these steps to restore your Toshiba to the Out of the Box condition. 1. Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on your notebook. 2. When the machine Starts beeping; release the 0 key. 3. When prompted by the warning screen; select Yes to continue with the system recovery. 4. Select Recovery of Factory Default Software; click Next. 5. Select Recover to out-of-box state. 6. Click Next again. 7. Click Next to Start recovery. 8. Restart the Toshiba laptop when there restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
12/31/2012 9:13:16 AM •
Toshiba...
Answered
on Dec 31, 2012
