SOURCE: I NEED BELT DIAGRAM FOR MY HUSQVARNA RIDING MOWER
http://www.usa.husqvarna.com/home.aspx try this out for your answers, I hope this helps you. MERRY CHRISTMAS!
SOURCE: MTD Lawn Tractor problem
The front belt should be a 954-0280A, rear 954-0370. When you go to higher gears, the front belt should be getting tighter as the vari-speed pulley is moving further back. Remove the shift plate, put the transmission in neutral. Start the engine, put speed selector in highest gear and slowly let out on the clutch. You should be able to see what the problem is. It will do everything the same as if were in gear, except move. Make sure you have the correct belts.
SOURCE: i cant get the drive mower belt on my poulan pro lawn tractor!
The belt you should have bought is part # 140294 and yes, it is longer.
SOURCE: i need to replace a mower deck belt on my exmark
There will be one or two "idler pulleys" besides the spindles that turn the blades. Usually one idler pulley is mounted on a plate that swivels, pulled by a strong spring, to put tension on the belt. The other idler pulley is usually fixed in place. Use strong pliers (vise-grips or channellock) to pull the spring out of its notch at one end, releasing the tension. Then the belt can be threaded. Now you have to restore tension by by pulling on the spring and anchoring it on that swivel plate again.
SOURCE: How do you replace a drive belt on a husqvarna cz4817
i just replaced my belt on a cz 4817. On one side there should be a bar with a spring on it. If you sitting in it it will be on you left side mounted on the deck itself. Push the bar in for about an inch and then up over the lip thats the belt tension spring. you should now be able to remove your old and put the new on. If you need the diagram to show you how to lace the new belt let me know and i will email it to you. good luck
