20 Most Recent Husqvarna Zero Turn Mower Z5426 Questions & Answers
On a Husqvarna Z254 Zero-Turn Mower, where does drive tension spring hook on right or left side?
Question edited for name of maker and '(what it is)'. Question moved from Cars and Trucks. See if the videos help. https://www.google.com/search?q=husqvarna+z254+drive+tension+spring ..
4/19/2022 1:23:41 AM • Husqvarna Zero... • Answered on Apr 19, 2022
3answers
Won,t move
Check the pump.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
8/12/2021 1:57:55 PM • Husqvarna Zero... • Answered on Aug 12, 2021
Zero turn belt
Manuals and Downloads You can download a manual from this site, belt information should be in the manual. Have model number ready.
1/17/2018 7:58:08 PM • Husqvarna Zero... • Answered on Jan 17, 2018
We just replaced the belt
First check your battery, it should be around 12.5 volts, if not it is the battery. Because you changed the deck belt, is the mower a manual engaged deck? Make sure the safety switches are working properly. Seat switch, brake switch. When trying to start, do you get 12 volts to the starter? If not, check the 20 amp fuse.
1/8/2018 9:05:14 PM • Husqvarna Zero... • Answered on Jan 08, 2018
How do know if the
Ensure you replaced the pulley correctly and that all parts are free to move and any spacers are correctly positioned. Before ANY DIY attempts at repairing machinery, ensure you remember where any small parts come from when stripping down. Keep all parts safely in the order they were removed and reassemble in the reverse order. If you fail to clean and (where required) lubricate parts, you will have problems with seizures. Finally, Did you have any bits left over?
1/3/2018 11:03:43 AM • Husqvarna Zero... • Answered on Jan 03, 2018
Zts 7500 manual
12/12/2017 6:25:36 PM • Husqvarna Zero... • Answered on Dec 12, 2017
Mower has warning light won oil
If the warning light says "chg oil" the meter is telling you it is time to change the oil. The meter will automatically re-set after 6-8 hours of run time. It cannot be manually re-set.
12/12/2017 6:25:12 PM • Husqvarna Zero... • Answered on Dec 12, 2017
Why when i engage the blades it thows the belt
Make sure the deck is set up properly, too much pitch down in the front can cause issues. Also, make sure the belt keepers on the deck pulleys are as close as possible. Spec says they should be at around 1/8" from pulleys.
12/4/2017 7:17:25 PM • Husqvarna Zero... • Answered on Dec 04, 2017
When i turn on the pto it blows the pto fuse
Make sure everything is able to move freely with the engine off. If the blades are not damaged or stuck, and the belt will rotate, it is either a bad electric clutch, the PTO switch or you have a wire(s) that is shorting to ground.
12/4/2017 7:10:31 PM • Husqvarna Zero... • Answered on Dec 04, 2017
How to stop check oil light from blinking and oil change been blinking 20 hrs after oil change
There is not a reset button. The gauge should blink for about 7-8 hours then stop. If yours continues to blink, it may be bad.
12/4/2017 7:07:24 PM • Husqvarna Zero... • Answered on Dec 04, 2017
My walker rider mower model mt pulls to the right how to adjust it ?
There are instructions in the owner's manual on how to adjust tracking: 5xfppff1lm4aaaaasuvork5cyii=
12/4/2017 6:42:42 PM • Husqvarna Zero... • Answered on Dec 04, 2017
Wont start after I enter the code
May need to have the code re-set. Your dealer can help re-set the code. Make sure your battery is fully charged.
10/26/2017 1:55:47 PM • Husqvarna Zero... • Answered on Oct 26, 2017
XP 60 inch zero turn/ When under load, the engine
Blocked main jet in the carb causes the engine to hunt.
8/19/2017 8:51:04 PM • Husqvarna Zero... • Answered on Aug 19, 2017
How do you level the deck on a z series zero turn husqvarna mower
The owner's manual is the best place for this information. However, when setting, make sure you measure blade tip to blade tip not the lip of the deck. Also, set between 1/8" to 3/8" drop in the front for proper function.
2/22/2017 2:57:57 PM • Husqvarna Zero... • Answered on Feb 22, 2017
My z5426 has allways left grass behind,i have to cut my lawn twice
Are your blades sharp? Are they lined up so they do not leave grass in between them as they spin? Is your cutting deck level or is one side higher than the other. These are all things that could cause long grass to remain. Some times a bent blade will do this also. I even had a lawn mower come in and the blades were installed up side down. He wondered why it would not cut right.
8/20/2016 1:31:36 PM • Husqvarna Zero... • Answered on Aug 20, 2016
Lifted the table to clean deck now blades won't engage when table is lowered
Probably disconnected the solenoid. Check all the wiring connection are in place and the solenoid is working.
7/13/2016 8:41:07 AM • Husqvarna Zero... • Answered on Jul 13, 2016
When i engaged the blades it blows the fuse
There is a fault in the blade engagement circuit. Using a multimeter or test lamp, check the switch, solenoid and wiring. Work logically and patiently and you will find the faulty component (tip - start with the solenoid) Good luck
7/13/2016 8:20:45 AM • Husqvarna Zero... • Answered on Jul 13, 2016
My zero turn husqvarna ran great last week. Know
Check and see if your getting battery voltage at the starter terminal when trying to start engine. This may take two people, one to sit on seat while turning the key to start and one to check to see if there is any voltage to starter when trying to crank. If there is battery voltage at the starter when being cranked, you have a bad starter. If you don't have voltage at starter when being cranked, check and see if there is a starter signal going to the starter solenoid. I'm not sure where it is exactly located on this peticular model but it is not that far from the battery. The main positive lead which is red in color goes to the starter solenoid first. Then there is another lead with the same thickness that goes to the starter from the starter solenoid. There should be a small wire between 14-16 gauge going to the starter from the ignition switch. Disconnect that small wire and check and see if your getting battery voltage when trying to crank engine. If you are getting battery voltage to the solenoid, the starter solenoid is bad. If your not getting battery voltage to the starter solenoid when cranking, check all safety switches that would cause the circuit to be interrupted, not allowing the starter solenoid to be energized. Hope this works out.
4/5/2016 1:59:52 AM • Husqvarna Zero... • Answered on Apr 05, 2016
Husqvarna Zero Turn Mower Z5426 Logo
266 questions posted
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
View Most Popular
Husqvarna Garden
  • Husqvarna Garden
Most Popular Question
get zero turn husqvarna steer straight
  • Garden
