SOURCE: New belt for Necchi Lelia 513-
Hi. I hear such wonderful things about these Italian-made Necchi! Here are a couple of places you should be able to find your belt:
http://www.sewingpartsonline.com/sewing-machine-belts.aspx
Guy Baker at http://www.sewingmachineparts.net/ always seems to have (or be able to get) just about anything.
http://www.sew4less.com/category/43/Belts_Motor_and_Timing
and, finally: http://sewing-machine-parts-store.com/list.asp?subcat=Belts
Hope this helps!
Happy Sewing!
Robbie
SOURCE: why is my singer SEWING MACHINE prelude HAND WHEEL RESISTING
Make sure the bobbin winder is in the position away from the bobbin stopper. When you fill a bobbin, you have to push the "spindle" towards the handwheel. If you do not push the "spindle" back into position (away from the handwheel), the wheel will remain locked.
SOURCE: Question about Necchi 537 FA
necchi's are good sewing machines, I personally own 2 necchi's,
and I've never had any problems with them and I've had them for around 10 years, here is what I suggest
use a new needle--one that is for the fabric your sewing
rethread the machine top and bobbin--use every thread guide
try a different bobbin
clean under the needle plate and in the bobbin area for lint
call a sewing machine repair shop in your area and ask them how
much a necchi sewing machine is worth or check on ebay and see
what they are selling for.
since you inherited the sewing machine,, having the machine
serviced completely would be a good idea, that way they can check
to see if the grease and oil that the gears and parts use is fresh or
needs to be replaced and it's very important the grease and oil are in
good condition.
and they can make sure the machine's is timed correctly
ask how much a tune up cost for a sewing machine and then
you'll have to decide if the price is what you want to pay.
also since the sewing machine is doing repeat loops from the bobbin
adjust the top thread tension just a little at a time till the stitch looks
normal on a scrap piece of fabric
if you don't have a manual on the sewing machine let me know & I'll try
to find you one.
I've been sewing for 30 years, and like I said I have 2 necchi's already
and I had one other one before these 2 that I have now and it lasted me
for around 15 years and I wore it out making clothes.
I wouldn't hesitate to buy or except another necchi because I know
they are good machines.
I have a mechanical and a electronic necchi and my husband uses the
electronic one when he makes quilts.
good luck on your decision
Merry Christmas and A Happy New Year
